Go Back   RCCrawler Forums > RCCrawler General Tech > New Products and Great Deals
Thread: Chaotic Switch 2.0 Bodiless Chassis - 20% Off
Old 08-04-2013, 11:02 PM   #1
Default Chaotic Switch 2.0 Bodiless Chassis - 20% Off
Thats Right....For a limited time only we will be giving
you 20% Off our Switch 2.0 Carbon Bodiless Chassis
Check out the website for more info...
www.chaoticcrawlers.com
Switch 2.0 Chassis
Includes:
2 - 1/16" Carbon Side plates
2 - 1/16" Carbon Side Cab Plates (reversible)
Custom 1mm thick one piece CNC machined Skid
7 - 35mm 3/16 Aluminum Standoffs - Drilled and tapped
2 - 3/16 Aluminum Cab Standoffs - Drilled and tapped
8 - 3/16 Aluminum Cab Spacers
Hardware (Choose your color)
Hardware and spacers for Upper links
Panels (.20 sides, hood and roof)
This chassis is a revision to our Chaotic Switch. We love the proven Switch but knew we wanted to take light weight to the limits. We cut away just about everywhere we could while still maintaining a very rigid and durable chassis. Many many hours have gone into the design and testing of this chassis to ensure that is will be a top performer. The skid is a unique one piece design thus eliminating the normal bottom mounting screws and preventing hang ups. All of the spacer and standoffs are drilled and tapped to make installation as simple as possible. We went with 3/16 aluminum spacers to keep the weight down and the strength up.
The most Unique thing about this chassis is the ability to Switch the cab. Just a few simple screws and you now have a completely different look. This should give the end user more options
Chaotic Crawlers is offline   Reply With Quote
Chaotic Switch 2.0 Bodiless Chassis - 20% Off - Similar Threads
Chaotic Super Switch Bodiless Carbon Chassis Chaotic Crawlers Superclass Crawlers 18 08-05-2016 04:24 PM
Chaotic Pro Bodiless Chassis Chaotic Crawlers Losi Mini-Rock Crawler 66 12-24-2013 06:09 PM
Chaotic Switch Bodiless Carbon Chassis...Tech thread Chaotic Crawlers Axial XR10 188 04-18-2013 08:27 PM
Chaotic Switch Bodiless Carbon Chassis Chaotic Crawlers Chassis and Suspension 167 04-18-2013 12:27 AM
