05-06-2012, 11:46 PM | #1 |
I wanna be Dave Join Date: Oct 2007 Location: 801
| Chaotic Switch Bodiless Carbon Chassis...Tech thread Chaotic Switch Bodiless chassis Tech Thread This chassis started off as a revision to our Chaotic Special. We love the special but knew we wanted to go carbon and figured why stop there. We didn't hold back with this chassis. Many many hours have gone into the design and testing of this chassis to ensure that is will be a top performer. The skid is a unique one piece design thus eliminating the normal bottom mounting screws and preventing hang ups. As usual all of the spacer and standoffs are drilled and tapped to make installation as simple as possible. We kept with the delrin spacers to keep the weight down and the strength up. Includes: 2 - 1/16" Carbon Side plates 2 - 1/16" Carbon Side Cab Plates (reversible) Custom 1mm thick one piece CNC machined Skid 7 - 35mm Delrin Standoffs - Drilled and tapped 10 Delrin Cab Spacers Hardware Hardware and spacers for Upper links Panels (.040 sides & .020 hood and roof) Weights: Chassis w/ Aluminum Hardware: 2.15oz or 62g Chassis w/ Black Oxide Hardware: 2.45oz or 70g Upper Link spacers and hardware Aluminum: 3g Black Oxide: 6g Panels: .45oz or 14g Click HERE for pricing or to purchased from our website along with titanium links for all of the Chaotic Special Chassis and more... Looking to have a great performing chassis on a budget??? Now Introducing the... Chaotic Switch Delrin Bodiless Includes: 2 - 1/8" Delrin Side plates 2 - 1/16" Delrin Side Cab Plates (reversible) Custom 1mm thick one piece CNC machined Skid 7 - 35mm Delrin Standoffs - Drilled and tapped 10 Delrin Cab Spacers Hardware (Aluminum or Black Oxide) Hardware and spacers for Upper links Panels (.040 sides & .020 hood and roof) Since the release of our Carbon Switch chassis we have wanted to make a more cost effective way for people to get into a great chassis. So here it is the...Chaotic SD. We didn't hold back with this chassis. Many many hours have gone into the design and testing of this chassis to ensure that is will be a top performer. The skid is a unique one piece design thus eliminating the normal bottom mounting screws and preventing hang ups. As usual all of the spacer and standoffs are drilled and tapped to make installation as simple as possible. We kept with the delrin spacers to keep the weight down and the strength up. Weights: Chassis w/ Aluminum Hardware: 2.65 oz. Chassis w/ Black Oxide Hardware: 2.95 oz. Upper Link spacers and hardware Aluminum: 3g Black Oxide: 6g Panels: .45oz or 14g www.chaoticcrawlers.com . Last edited by Chaotic Crawlers; 09-11-2012 at 12:04 AM. |
05-06-2012, 11:48 PM | #2 |
| Re: Chaotic Switch Bodiless Carbon Chassis...Tech thread This is the future home of the Chaotic Switch Tech section If you have any question, comments, set up tips or advice please feel free to post up. |
05-07-2012, 06:12 AM | #3 |
Pebble Pounder Join Date: Feb 2012 Location: wooster
Will the xr10 "special" chassis links fit this new chassis? Or will new links also be needed?
05-07-2012, 06:54 AM | #4 |
The links are the same. |
05-07-2012, 07:24 AM | #5 |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
tried to order, says it's out of stock but since this is a tech thread, i think the first, most obvious question is, what length shocks are these intended for? Last edited by T3rry; 05-07-2012 at 07:27 AM. |
05-07-2012, 08:01 AM | #6 |
Newbie Join Date: Feb 2012 Location: Carthage
So much want! One of the best looking chassis yet! I'm running your special LW now but may have to upgrade to this! Great job!
05-07-2012, 09:18 AM | #7 |
It was designed to use a 3.5" or 3.75" shock. You can use a 4" but would need to do some internal limiting. I believe I already know of 1 person that plans to run a 4" shock. So we will see how he likes it. |
05-07-2012, 12:15 PM | #8 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
ya im going to try the losi shocks out but i have mine limited to 3.5 on the front . i will post it all up once i see how it works
05-07-2012, 12:20 PM | #9 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
| Re: Chaotic Switch Bodiless Carbon Chassis...Tech thread |
05-07-2012, 12:24 PM | #10 |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
I plan on tryin just about every shock & length I can with this chassis. I think that the 3.5" with a soft spring & mid weight oil will prove best overall but we shall see. J.D. |
05-07-2012, 12:26 PM | #11 | |
Quarry Creeper Join Date: Nov 2011 Location: Thunder Bay, Ontario
| Re: Chaotic Switch Bodiless Carbon Chassis...Tech thread Quote:
Are all the bodiless by CC not designed to work with the stock springs of 4"? Are they all 3.5 or 3.75? How would u limit it? | |
05-07-2012, 12:40 PM | #12 | |
3.5" and 3.75" shocks just reduce or eliminate the need for internal spacers and allow for more range of motion. | |
05-07-2012, 12:45 PM | #13 |
Quarry Creeper Join Date: May 2007 Location: home
I ran 3.5" Big Bores on the front of my Special and 3.75" Big bores on the rear. But Im guessing with this new set up I will be going with the 3.75" all around!! |
05-07-2012, 01:34 PM | #14 | |
05-07-2012, 01:43 PM | #15 | |
cant wait for this chassis to be released, i have everything i need for my new build, except the chassis/links/steering link | |
05-07-2012, 01:50 PM | #16 |
The L, XL, XXL is the length.. If i remember correctly the cap mod adds 1/4" if using the small 3mm traxxas rod end. Measurements with cap mod: Traxxas Big bore #2660 L= 3 3/4" Traxxas Big bore #2661 XL=4" Traxxas Big bore #2662 XXL=4 1/4" I'd suggest starting off with L or Xl's all around These aren't the only possible shocks...but are very smooth. I'll try to work up some part numbers and other shock options. Last edited by Chaotic Crawlers; 05-07-2012 at 02:37 PM. |
05-07-2012, 02:24 PM | #17 |
RCC Addict Join Date: Nov 2011 Location: Surrey,BC- Canada
i think the part numbers are L big bore part #2660 XL BB Part #2661 XXL BB Part #2662 The Xl's are hard to find.Well up here in canada. |
05-07-2012, 02:59 PM | #18 |
i got the traxxas 4962, it is for the maxx trucks, comes with 8 shocks, for only marginally more than 4 shocks, so i just split em with a friend... tower says they're 4-1/8 uncompressed, i dont mind limiting them internally.
05-07-2012, 03:21 PM | #19 |
RCC Addict Join Date: Jan 2009 Location: O.C
05-07-2012, 03:53 PM | #20 |
Chaotic Switch Bodiless Carbon Chassis...Tech thread - Similar Threads | ||||
Chaotic Pro Bodiless Chassis | Chaotic Crawlers | Losi Mini-Rock Crawler | 66 | 12-24-2013 06:09 PM |
Chaotic Switch Bodiless Carbon Chassis | Chaotic Crawlers | Chassis and Suspension | 167 | 04-18-2013 12:27 AM |
~Chaotic Special Bodiless....Pro Edition~ *NOW IN CARBON FIBER* | 53 willys | Axial XR10 | 160 | 03-24-2012 10:31 AM |
First setup runs Chaotic Crawlers Special Bodiless XR10 Carbon | nicodrive01 | Videos! | 5 | 02-24-2012 09:10 PM |
Chaotic Crawlers Pro Bodiless Chassis | xgerstandtx | Losi Mini-Rock Crawler | 4 | 10-22-2011 09:20 AM |
