07-07-2009, 12:37 AM | #1 |
Rock Stacker Join Date: May 2009 Location: lville
| new to crawling
here is my truck any advice on what i should do? |
07-07-2009, 12:47 AM | #2 |
WOOPOOW!! Join Date: Nov 2008 Location: Atlanta, GA
Hey, Glad to see you finaly showed up! Heres some advice: First off, I would get ahold of some good bent lower links. Those ones you have now will bend/break and what not, ive seen the way you drift http://www.tcscrawlers.com/On-Sale-5...n-p-16648.html Next thing I would do is replace all of your steering linkages with some nice anodised stronger material, which I have: http://www.tcscrawlers.com/Axial-Rac...2-p-16685.html I will bring that to the comp next weekend. The next thing I would look into is a new set of shocks, that will be on you. You have alot more flex than needed, try stiffer springs, or spacing the spring out a bit. I have some stiffer springs if you would like. Next thing, a battery. I gave you some good links for batteries, but these are always easy to use: http://www.tcscrawlers.com/TCS-Crawl...r-p-16949.html Remember to post all your questions in your build thread. I know you know that, but if you need imediate help, post in the forum it applies to. Last edited by Colby; 07-07-2009 at 12:50 AM. |
07-07-2009, 12:50 AM | #3 |
| Battery mount, and a Traxxas or deans connect. Oh and don't let the cat steal your crawler's Thunder! |
07-07-2009, 12:52 AM | #4 |
May also want to check this thread out: Axial tips and tricks |
07-07-2009, 12:54 AM | #5 |
07-07-2009, 12:54 AM | #6 | |
07-07-2009, 01:13 AM | #7 |
No prob man, we'll get ya set up. If anything just drop the rig off and I will work some colby magic (Sometimes thats a bad thing) :-P
07-07-2009, 05:19 AM | #8 |
Newbie Join Date: Mar 2008 Location: Tempe
yeah looks like a battery mount would serve you good
07-07-2009, 09:31 AM | #9 |
07-07-2009, 09:32 AM | #10 |
07-07-2009, 09:42 AM | #11 |
another thing would be to get lower aluminum links or delrin, and get a saddle pack battery and strap it to the front axle and you will notice a huge diffrence. weight your wheels if you havent, put your axial foams in the losi rock claws if you have them.
07-07-2009, 11:51 AM | #12 |
| im gonna get those soon. i have weights on the wheels and it makes a big difference wich thats the way i got it but i can tell the difference. and i have memory foam. so the axials would be better? thanx for the advice. |
07-07-2009, 12:13 PM | #13 |
Rock Crawler Join Date: Apr 2008 Location: Lexington
After you do all that was suggested above, try looking into getting rid of the 3 link uppers and go for a 4 link setup. After you do all that, you'll be amazed at the difference in performance!! |
07-07-2009, 12:19 PM | #14 |
07-07-2009, 01:20 PM | #15 |
Quarry Creeper Join Date: Jul 2008 Location: casa grande
There is alot of good information given by colbythekid the best is the TCS web site. Once you get the feel for building and re-building your rig, and looking at other drivers rigs you will see what you may want to change or even keep. personaly I went over axle batts, Losi 4.0 shocks, new esc (Sidewinder), tires, dig unit, and weights in all 4 wheels. These are just a few thing I did to mine. Lets see some more pics when you get some new hardware on the beast. OH and when all else fails that is when you go Berg. LOL |
07-07-2009, 01:27 PM | #16 |
| depends on your rig but the axials work good for me, also it depends on where you run with memory foam and i run my memory foams in the summer time and standard in the fall amd winter. i love the losi crawler shock they are great, nice and smooth, along with lots of adjustments. id also recomend the 7 or 8 cell saddle packs the are awsome and give more speed to your motor
07-07-2009, 02:49 PM | #17 |
Quarry Creeper Join Date: Sep 2008 Location: tucson
Hi some wheel weights would be very helpfull and a set of tires about bent links im using the real dogmans links and havent broke them yet.
07-07-2009, 03:19 PM | #18 | |
07-07-2009, 03:20 PM | #19 | |
07-07-2009, 03:22 PM | #20 |
| ok well i went to hobbytown and bout the hardeware for the bent link and two bent axial links thats all the money i had at the time so soon ill get the other two then mount them on and i will post pics up.
