Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Painting a HardBody..Prime or not to Prime?
Old 06-07-2019, 02:11 PM   #1
Default Painting a HardBody..Prime or not to Prime?
So, I've been following/reading a bunch of painting threads in preperation for this...but I keep getting different answers, depending on who you ask, so I'm hoping maybe someone here has 'the definitive'
Hardbodys (For me, specifically, its the Tamiya Sand scorcher body)...
I get that you need to prep this style of body (Or all bodies for that matter)
So here's the steps I'm hearing
Wash it (Super Green, or dish soap)
Scuff it (Sandpaper, preferably wet)
Wash it again and let it dry...
Wipe it down with a cloth
Then, this is where it comes all the random posts not making any sense...do you prime this? Or because its a plastic, do you just use a Tamiya plastic paint, since its ment to adhere to plastic?
What do you do? What are your steps for a hardbody?
Dracnus is offline   Reply With Quote
Old 06-07-2019, 03:15 PM   #2
Default Re: Painting a HardBody..Prime or not to Prime?
Follow the paint manufacturers recomendations.
Inspector86 is offline   Reply With Quote
Old 06-07-2019, 03:19 PM   #3
I just use a bit dish soap to wash the body if its really dirty.
I use green scotch pads to scuff up the body. Tamiya paint goes straight on the plastic. No primer.
HugoBiermann is offline   Reply With Quote
Old 06-08-2019, 07:59 AM   #4
Is that just Tamiya? Or will lexan acrylics work ok too? Specifically Spaz Stix and Parma Faskolor.
punkindrublik is offline   Reply With Quote
Old 06-08-2019, 02:08 PM   #5
Tamiya ps paints goes straight onto lexan and sticks really good. Ask enyone. Sticks even better on styrene bodies.
I use rustoliums paiters touch too and its good. As long as its a really good acrylic I have found.
Old 06-08-2019, 02:47 PM   #6
I like to paint the body with rust colored primer first, then a thin layer of white paint then my top color. My latest build I started I did it this way so it looks like it has been weathered down through the clear coat and to the primer and finally down to bare metal and started rusting.
It takes practice to get the color to show the white and rust color the way you want. I still have a good bit of detailing on this to go but this is where it sits now.
struhall is offline   Reply With Quote
Old 06-10-2019, 12:04 PM   #7
thats simple, and gorgeous. really like that idea. I have an air compressor/gun that I use for minis (warhammer) and could mix some primer red with some copper paint to really get a good rust layer going, so this might be a really good way to go.
I already tried up the beetle body a bit and this is where I'm at
Just gotta figure out how to weather the door and clean up my rust lines..you can tell its painted on, on the fenders.. :S
Old 06-10-2019, 03:47 PM   #8
If you're trying to get a real good rust look you can do the salt method. You get all your body work done and dents and rust holes done and then paint it with the rust red primer. Once that sets you must it with water and sprinkle salt where you want it to be rusty. You shoot your top color of paint on that and then once its dry you wash and scrub away the salt to show the rust underneath.
Check my build thread for my Hilux and you can see how I did the salt method for rust.
Struhall's C2 Scx10.2 Hilux
Old 06-16-2019, 08:20 PM   #9
If you're scuffing, you're basically doing the same thing as priming. Giving the paint something with some texture to adhere to. Paints specifically for RC bodies are usually designed to self etch the shell, to go ahead and remove the need to scuff or prime. Priming actually worsens the adhesion since it's not etching/bonding with the plastic. If you're planning on using other types of paint (actual automotive paint, scale model acrylics, etc) then scuffing or priming isn't a bad idea.
GCi in ATX is offline   Reply With Quote
Old 06-17-2019, 01:36 PM   #10
Thats good to know. I was using Tamiya paints, and I scuffed it up a bit, but only with like...a cloth, not even sand paper grit. It seems to really stick!
Old 06-17-2019, 01:56 PM   #11
Tamiya paints will stick on almost any plastic used in modeling / RC. They’re that good.
Like I’ve said, use these to make sure the surface is just roughed up enough:
Old 06-17-2019, 02:01 PM   #12
I was at a loss for what those are called 'Scuffing pads' :P
That is precisely what I used. Keeping a kit in the workshop from now on.
Old 06-17-2019, 02:07 PM   #13
3M Scouring Pads to be specific
Painting a HardBody..Prime or not to Prime? - Similar Threads
Prime Day calcagno45 Chit Chat 8 07-11-2017 07:12 PM
LG Prime users... Duuuuuuuude Chit Chat 12 07-01-2011 08:42 PM
Maxximus Prime DISTURBIN' tha PEACE Traxxas Crawlers 18 10-22-2005 03:10 AM
V-Prime Rip-Off? utbeamer Tamiya Clod Buster 106 09-28-2005 04:55 AM
V-prime 2.2 wrx-n-ktm Tamiya Clod Buster 9 09-27-2005 05:34 PM
