10-29-2009, 07:46 PM | #1 |
Newbie Join Date: Oct 2009 Location: Ocean Springs, Mississippi
| what parts do i need
im trying to build a scale crawler from the ground up and i dont exactly know what parts i need to do it
10-29-2009, 07:48 PM | #2 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
tires, wheels, shocks, links or leafs springs,axles, chassis, ESC, TX.RX, motor, tranny, drive shafts, body, battery, some screws and bolts, some nuts really the only differance between scale and comp is chassis, shocks (scale is shorter) and body, oh and scales have to be shafty |
10-29-2009, 07:54 PM | #3 |
what is tx.rx??
10-29-2009, 08:06 PM | #4 |
transmitter and receiver. it sounds like your a beginner to rc. Maybe look into somehting like the axial scx10 trail ready http://www.axialracing.com/ftp/scx10tr/index.html it comes ready to run and is a agood reliable capable starting point, then as time goes on and you learn more you can start to change parts around and upgrade and tune the rig to suit your terrain and driving style Last edited by ultimate_monkey; 10-29-2009 at 08:08 PM. |
10-29-2009, 08:15 PM | #5 |
i have a ax10 scorpion with a few comp hop ups but i never learned what everything is on it my dad put all the hop ups on it and he had to use instructions so i just need a few questions answered and ill be good to go like what exactly is the tranny? |
10-29-2009, 08:27 PM | #6 |
Rock Crawler Join Date: Sep 2007 Location: University City
| tranny=transmision, the thing the motor goes into and the driveshafts come out of. Building a truck (be it comp or scale) from the ground up requires some know-how, and the ability to modify parts to fit. Honestly i think your much better off starting with a axial trail ready...
10-29-2009, 08:28 PM | #7 |
tranny- transmission, on your ax10, the tranny is the centered gear box with the drive shafts attached and also the motor and motor plate bolted to it. looks like this if you have the instruction booklet that came with the ax10 i suggest you read threw it, it will show you every part in the truck, where it goes, and how it goes togeather |
10-29-2009, 08:31 PM | #8 |
one more thing do i want to buy axles that are locked or not?
10-29-2009, 08:33 PM | #9 |
ohh yeah and are links all the orange tubing all over my ax10?
10-29-2009, 08:34 PM | #10 |
yes all the orange tubes are the "links" there should be 4 per axle, and locked axles give you moer traction but you loose the ability to make super tight turns,
10-29-2009, 08:36 PM | #11 |
and if i get locked axles am i supposed to get a locked transmission
10-29-2009, 08:38 PM | #12 |
the axial transmission comes locked from the factory it sounds like you could bennift from reading threw this thread Live Axial AX-10 build |
10-29-2009, 08:42 PM | #13 |
thanks for all the help and if i need anything else i will be sure to contact you somehow
10-29-2009, 08:45 PM | #14 |
sure, just shoot me a PM if u need any thing, just click my name and u should see the PM button
10-29-2009, 08:49 PM | #15 |
I wanna be Dave Join Date: Dec 2007 Location: Not here
| Beadlocks"thumb sup"
10-29-2009, 08:52 PM | #16 |
10-29-2009, 08:55 PM | #17 |
Newbie Join Date: Oct 2009 Location: Hillsboro
That is cool how you helped him out Mr. Monkey! |
