12-30-2009, 01:57 PM | #21 |
Newbie Join Date: Dec 2009 Location: BFE
| If you look at the numbers involved it makes it easy. Most of the ESC's that Iv'e looked at on;y put out 5 amps to the servo. This includes high end ESC's. The CC BEC puts out 10 amps. The fact is, a BEC is better than not. |
12-31-2009, 06:02 PM | #22 |
Rock Stacker Join Date: Dec 2009 Location: stockport ohio
well im having the same problem, to poor to get a bec yet but i will. im running a evx-2, 9100t, and a fan on the motor to keep it cool with a 4-cell. if i plug an external battery like a reciver pack, in the reciever do you think it will work or burn my reciver up?
01-01-2010, 10:26 PM | #23 |
Newbie Join Date: Oct 2009 Location: Syracuse
yes but makes sure you remove the red wire from your esc plug that plugs into the receiver the main thing that will do is give your steering servo more amps not pulled from the esc and more voltage downside to a receiver pack is extra weight but it will do what you need
