11-12-2009, 07:08 PM | #1 |
Newbie Join Date: Sep 2009 Location: roseburg
| esc is effected by my servo
every time i try two steer it completly shuts my esc down when i unplug my servo the esc runs fine what to do
11-12-2009, 07:09 PM | #2 |
Rock Stacker Join Date: Aug 2009 Location: LITH
What kinda esc and servo r we talkin bout? Does ur ESC turn off or the vehicle just dosen't go.
11-12-2009, 07:12 PM | #3 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
You running 3s? Whats your setup? |
11-12-2009, 07:25 PM | #4 |
Rock Crawler Join Date: Sep 2009 Location: Abbotsford BC
what servo, esc and truck do you have??? i have this issue running 2 servos with my esc, if im turned to full lock front and back the truck wont drive. as soon as i let off the rear steer it runs just fine. i believe in my case the bec in the esc cant supply the current to hold the 2 servos at full lock. |
11-12-2009, 07:38 PM | #5 |
Sounds to me like you guys need a Castle BEC. |
11-12-2009, 11:29 PM | #6 |
RCC Addict Join Date: Jun 2008 Location: Fresno
11-13-2009, 10:43 AM | #7 |
what kinda bec and how much do they usually run
11-13-2009, 10:56 AM | #8 |
Quarry Creeper Join Date: Dec 2008 Location: Suburbs
yea get the Castle 10amp bec...seems like your over doing it
11-13-2009, 07:32 PM | #9 | |
| The one I gave you a link to..... Quote:
12-19-2009, 11:30 AM | #10 |
Newbie Join Date: Dec 2009 Location: BFE
| Would an external BEC still be better than running an internal BEC? |
12-19-2009, 11:35 AM | #11 |
Rock Crawler Join Date: Dec 2008 Location: Displacement
12-21-2009, 11:56 AM | #12 |
| I took the advice and got a CC BEC. Took a little while to wire it up properly, but I did figure it out. I took it for a test drive and noticed a marginal difference. The ESC no longer takes a S!!it when I'm in a bind, but the steering is not much stronger if any. Any suggestions? |
12-22-2009, 08:46 AM | #13 |
| So, I took my servo apart and made sure everything is running well and lubed everything. Put it back together and now I have strong responsive steering. |
12-28-2009, 07:10 AM | #14 |
Quarry Creeper Join Date: May 2008 Location: Ontario, Canada
I had the same issues and a cc-bec fixed it!!!
12-29-2009, 03:17 PM | #15 |
Pebble Pounder Join Date: Oct 2009 Location: lakeside
what if your using a reg batt not lipo and its doing that
12-29-2009, 03:22 PM | #16 |
it can happen with any type of battery not just lipo, just most esc's that can handle 3s lipo need a bec to keep the temps down
12-29-2009, 06:07 PM | #17 |
so a new servo wouldnt fix this problem right or??
12-29-2009, 06:08 PM | #18 |
or would a better esc fix the problem?
12-29-2009, 08:06 PM | #19 |
Pebble Pounder Join Date: Dec 2009 Location: Ottawa
No , a BEC is needed . I run what I think is the best ESC [Tekin RS Pro] and the internal BEC is not enough . I didn`t think I needed one but once I threw in a 3S lipo it was very obvious .
12-29-2009, 09:35 PM | #20 |
coo thanks got it so the bec is a sep thing i need to add on to any esc and evenmore when i go lipo |
