10-31-2010, 01:09 PM | #1 |
Pebble Pounder Join Date: Oct 2010 Location: Marengo Oh
| Goat 3s help
I have a goat 3s in my honcho I just got both and I got the 3s hooked up right a to a b to b and c to c and the radio is set up right (DX3R) well anyway when it goes forward it is slow and when in rev it is fast also not sure if the gearing is right does anyone know what a 18.5 should b geared at on that truck?
10-31-2010, 02:39 PM | #2 |
Rock Stacker Join Date: Aug 2010 Location: Good. Green. Oregon.
Hey man, I have the Goat 3s too, and mine, although brand new, is back at Novak getting repaired/replaced. Before it just crapped out, it did the same thing. Forward was slow, as I figured it would be for good torque for crawling, but the strange part is that reverse was really fast and not very controlled. I had the intention of reprogramming it, but then it quit working altogether. Have you tried any different settings on it by using the programming feature? Frankly, I was unhappy with mine, considering I haven't been able to drive my Honcho yet, and now I have to wait for it to be sent back. In addition, the install is kind of a pain with all the wires! Keep me posted on if reprogramming it helps, or if you figure anything out with the speedy reverse. Are you using 3s?
10-31-2010, 06:01 PM | #3 |
| just 2s
I did reprogram it a couple times still the same I might give them a call tomorrow.
10-31-2010, 10:30 PM | #4 |
You could also either post in this thread: Official Novak Crawler Products Thread Or, PM the guy named Charlie that posted in that thread, as he is an employee of Novak and said he is here to help. |
11-01-2010, 09:32 AM | #5 |
RCC Addict Join Date: Jun 2006 Location: hillsborough
Try reversing the throttle ch and then reset the one touch
11-01-2010, 05:15 PM | #6 |
| I tried that. |
11-01-2010, 07:38 PM | #7 |
list everything your runnin, motor, esc, rx servo etc
12-13-2010, 03:40 PM | #8 |
Newbie Join Date: Nov 2010 Location: enderby bc
you need to callabrate with the controler and esc
