Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Help please!!!
Old 03-01-2011, 12:40 PM   #1
Default Help please!!!
I am really new to the RC world!
I got the Maxstone 8. I would like to upgrade my servo to something that has more torque, however i am clueless when it comes to how servos mount.
Are they universal mounting or do i need to find a plate or fab something?
KnoJa is offline   Reply With Quote
Old 03-01-2011, 12:55 PM   #2
Suck it up!
Duuuuuuuude's Avatar
Any standard size servo will fit.
Duuuuuuuude is offline   Reply With Quote
Old 03-01-2011, 01:14 PM   #3
So the HS-7980TH Servo would work?
Want to get something with high torque.
Old 03-01-2011, 01:18 PM   #4
for that thing try a hitech 645mg, 30 bucks
crawlhog is offline   Reply With Quote
Old 03-01-2011, 01:26 PM   #5
he wants a STRONG servo, not a little panty waist dig servo
the 5980 may take a little bit of work to wedge in there,
being it is a lil bigger than a STANDARD servo, as the duuuuuuuude said
But the 7950's, Jr9100t, 8711 etc all fit perfect.
BEELZEBOB is offline   Reply With Quote
Old 03-01-2011, 01:29 PM   #6
Actually, that servo is slightly larger than most standard size servos....so, something like the 7950 would be perfect.
However, keep in mind that the numbers for both of those servos are at 7.4V.....you'll need an external BEC wired directly to the servo to get that voltage to the servo and get out those torque ratings...
JeremyH is offline   Reply With Quote
Old 03-01-2011, 01:47 PM   #7
sorry beezledope maybe i should read better next time. not everyone is as smart as you jackass
Old 03-01-2011, 01:48 PM   #8
bingo!!!! that size torque, X2 you will need an external BEC, otherwise that thing will have the siezures
ped453 is offline   Reply With Quote
Old 03-01-2011, 01:51 PM   #9
Beelzedope?
thats a good one because it works on many levels.
and yes, KnoJa, a BEC is going to be a vital implement!
Old 03-01-2011, 02:51 PM   #10
Any recommendations for the BEC?
Also i saw a post in here on having 2 servos up front. Is that possible or did i miss read?
How the hell would you mount two in the front if that is the case?
Old 03-01-2011, 02:52 PM   #11
Castle Creations BEC. You'll need the Castle Link to program it to different voltages (stock is 5.1V)...
Old 03-01-2011, 03:00 PM   #12
So get those two things and program to 7.4V and i'll get the most out of the servo?
So if i want to do rear steer, i need to do the same and buy the steering linkage?
If i do rear steer, how will that affect the battery life?
Old 03-01-2011, 03:09 PM   #13
Yes, BEC's will allow you to run the servo and the castle link allows you to program the BEC.
Rear steer will require a second set of; C-hubs, knuckles, links, a servo and servo horn.
A lil bit. but not like running an additional motor or anything.
Old 03-01-2011, 03:49 PM   #14
Cool! Thanks for the info.
hopefully i can get this thing to do some serious crawling! (I know, Exceed isn't the most popular brand! But damn its fun!!)
Old 03-01-2011, 03:51 PM   #15
Since you more than likely will not be able to run that amount of voltage through your receiver, you will also need to pick up a y harness like this one:
http://www3.towerhobbies.com/cgi-bin...1&I=LXYPS5&P=K
And pull the wires like this:
Old 03-01-2011, 03:53 PM   #16
Will that affect the battery life? Should i upgrade to 2 batteries in series (or is it parallel)?
Old 03-01-2011, 04:00 PM   #17
Minimally....no need for two batteries. On my super, I run dual high torque Brood motors, and two Hitec 7980's set for 7.4V each along with a 850mAh 4S Krawler Hobbies lipo and I get about 15-20 minutes per pack...
Old 03-01-2011, 06:02 PM   #18
I think im missing something! you have a total of 4 motors or am i just being an idiot?
A couple of my friends have been trying to talk me into using 770 motors. Is that a bad idea?
Old 03-01-2011, 07:10 PM   #19
idiot??, that remains to be seen.
He is running 2 motors & 2 steering servos plus the RX. That is all.
Charlie-III is offline   Reply With Quote
Old 03-01-2011, 07:18 PM   #20
Nope....just two motors, two ESCs, two 7980's and one big ass BEC!
Not sure on the 770s....I run 540's on my super.
