05-01-2012, 10:35 AM | #1 |
Newbie Join Date: Apr 2012 Location: yerington
| Best drive shaft for a scx10
What do you guys recommend for a drive shaft for a scx10?
05-01-2012, 10:42 AM | #2 |
The usual consensus is either mip or maxx shafts. Have a search for yourself. |
05-01-2012, 11:29 AM | #3 |
| Re: Best drive shaft for a scx10
well i have searched but a lot of the mip shasts look different and im not sure of which ones
05-01-2012, 11:39 AM | #4 |
Rock Crawler Join Date: Oct 2011 Location: Warren
Just use the MAXX Shafts search to see the exact part numbers. They are all you need. I rund my truck with a 45turn on 4S and have yet to break one. Then again I dont typically put the truck in much of a bind. When it gets bound up plastic parts break. That is just common sense.
05-01-2012, 12:46 PM | #5 | ||
| Re: Best drive shaft for a scx10 Quote:
Edit: go here and check out the xref table as well http://miponline.com/store/Axial_Hop-Ups.html Quote:
05-01-2012, 09:21 PM | #6 |
Rock Crawler Join Date: Jul 2008 Location: Dutch Oven - AZ
A few guys running scalers locally like the Junfac Carbon Steel driveshafts... Sent from my SGH-T959V using Tapatalk 2 |
05-03-2012, 11:11 PM | #7 |
Newbie Join Date: Nov 2011 Location: united states
I run the junfac shafts and like them alot,have not had one problem with them. I'm running a 65 turn and big nimh batts.
08-19-2013, 05:43 AM | #8 |
Newbie Join Date: Mar 2013 Location: sweden
I did just blow (10 minutes ago) my 2 junkfac drive shaft when i tryed 6S in my Honcho. first i cracked the rear, then i rived with just FWD for a minute then that one craked as well... I was quite surprised about that.... Guess i have to try MIPs shaft now. Or do you gyus have any suggesition about better driveshafts-? Sorry for my lack in english. |
08-19-2013, 06:56 AM | #9 |
RCC Addict Join Date: Dec 2008 Location: Sonora, CA
All of my rigs run MIP.
08-19-2013, 07:47 AM | #10 | |
08-19-2013, 08:41 AM | #11 | |
MIP C-Drive Spline Set for Axial AX10 Scorpion (2) The cross pins are Traxxas Screw Pin 4x15mm #5145. Traxxas Screw Pin 4x15mm Revo (6) | |
08-19-2013, 05:31 PM | #12 |
| Re: Best drive shaft for a scx10 The female part of the shaft cracked on both sides (front and rear) Were you insert the male shaft, you have like 5mm or something that acctually have conection to each other. It snaped right after thoes 5mm. I will see if i can post a image of it later today, now i haft to run to work.... |
Best drive shaft for a scx10 - Similar Threads | ||||
scx10 drive shaft upgrade? | Physical Terrorist | Axial SCX-10 | 5 | 02-23-2011 02:57 AM |
axial scx10 dingo, drive shaft | popit1991 | Axial SCX-10 | 0 | 12-30-2010 02:19 PM |
SCX10 drive shaft | Monster Crawler | Newbie General | 9 | 02-09-2010 09:14 AM |
