10-16-2012, 04:47 PM | #1 |
Newbie Join Date: Sep 2012 Location: missouri
| gearing question
I went to my local hobby store and asked a question about a motor he said the motor doesn't matter it's the gearing.Then why do they make different turn motors???? |
10-16-2012, 06:26 PM | #2 |
Quarry Creeper Join Date: Jan 2012 Location: Central Florida
| Re: gearing question
The lower turn means faster speed,10t or 12t. The higher turn means more torque and less speed,27t,35t,55t |
10-16-2012, 06:49 PM | #3 |
I'm looking for something that still has crawling ability but has good speed.
10-17-2012, 12:21 PM | #4 |
Quarry Creeper Join Date: Oct 2012 Location: high desert CA.
| Re: gearing question im looking for the same thing im running a 55t now but swithing to a 35t motor,, also it can be gearing if you are running a 2 speed trans, you would be able to crawl, then change gears and hammer down thru the mud,,,
10-17-2012, 12:34 PM | #5 |
In a SCX10? Do you have the stock esc? How much money do you want to spend? Are you runninig lipo batteries? If so, what volt? |
10-17-2012, 02:36 PM | #6 |
scx10. stock esc. willing to spend around 30. am running NiMH 3800mah.also running stock and smaller tires
10-17-2012, 02:44 PM | #7 |
hmmm, you should consider running lipo. It's a small investment but you get a lot out of it. I'm pretty sure the stock esc can handle 2s lipo. That will give you slightly more power over the NiMH. In your price range, I'd look at an Integy 35t motor. If you can get a few more bucks together, look into Holms Hobbies 13t-16t Crawl Master or a 30t-35t Torque Master. You can find them used here on RCC and they are rebuildable. |
10-17-2012, 02:49 PM | #8 |
curently I have a 27t motor,24t pinion, stock spur.If i get a smaller spur will that work for a little bit more speed.
10-17-2012, 02:54 PM | #9 | |
| Re: gearing question Quote:
Smaller Spur or larger Pinion = More Speed and Less Torque Smaller Pinion or larger Spur= More Torque and Less Speed | |
10-17-2012, 03:00 PM | #10 |
im looking for the perfect balance.Before i had a 20t pinion and a slot machine that worked great i just want that back.
10-17-2012, 05:14 PM | #11 |
The perfect balance eludes us all. Yes a smaller pinion will help a little with speed.
10-17-2012, 05:24 PM | #12 |
Perfect combo: BR-XL running a 14t Puller on 6s |
10-18-2012, 03:07 PM | #13 |
thinking about a 80t spur will that majorly affect my speed or torque.
10-18-2012, 03:11 PM | #14 |
what's your current spur?
10-18-2012, 03:21 PM | #15 |
stock 82t
10-18-2012, 03:28 PM | #16 |
no, you'll need to make a bigger jump than 2t.
10-18-2012, 03:32 PM | #17 |
what would you suggest I'd like to get atleast 10 out of it.
10-18-2012, 03:38 PM | #18 |
I'm not sure, I've never run that motor, battery, 48 pitch or stock gearing ratio... but if I was looking for a drastic change, I'd drop to a 65-70... but you'll loose torque. You could ask in the SCX10 forum... or try here: What powers your SCX10? |
gearing question - Similar Threads | ||||
Another gearing question | tim the toolman | Formula Offroad | 4 | 10-20-2011 09:02 AM |
Gearing question??? | shmangi | General Crawlers | 15 | 03-31-2011 04:21 PM |
Gearing Question: | xxgg | Axial SCX-10 | 1 | 06-06-2010 08:55 AM |
gearing question | creepingcrawler | Newbie General | 6 | 01-13-2009 12:21 AM |
Gearing Question?? | kerrywittig | Axial AX-10 Scorpion | 16 | 07-21-2008 10:47 AM |
