01-11-2013, 02:50 PM | #1 |
Newbie Join Date: Dec 2012 Location: Englewood
| I took the plunge
Yep I did it, the Honcho is on its way, I probably will be back yard bashing in AZ. and rock crawl-in in CO. But now I got to figure out what charger & battery. Last time I dealt with this I had a old hornet you just plug in the battery and set the timer for 15 min. and went and played, now you got all different batteries and balancing to do. What is good all around stuff? I know I need ac/dc charger. |
01-11-2013, 03:26 PM | #2 |
Pebble Pounder Join Date: Oct 2012 Location: Graham WA
| Re: I took the plunge
Tons and tons of good, all around stuff. From my experience you can spend 200 bucks on a charger or 50, there both gonna do the same thing. batteries are the same. but you need to figure out what you want as far as size, or how long you want it to last before anyone can recommend anything. want lipo or no? want to drive for a couple hours, or 20 min before recharging? <<this is more if you want lipo, not much for choices on NiMh Check the SCX section for possible ideas. |
01-11-2013, 04:17 PM | #3 |
WOW you can actually run these things that long, on a charge what size battery is that???
01-11-2013, 06:13 PM | #4 |
It all depends on your setup and how you drive. But with a 5k mah 2s, I ran my crawler for way over an hour. It sucked as it was way too big for my rig, and I've since downsized. But you scaler guys can get away with it. Check around and read up. especially if your new to the lipo scene. There not the most user friendly battery, but common sense takes care of most the worries. I aint never blow'd one up yet. |
01-11-2013, 07:01 PM | #5 |
Quarry Creeper Join Date: Dec 2012 Location: Spokane Valley
I run a 2100 mah 3s lipo and I got 1 1/2 hours and it still wasn't dead. That's on a superclass crawler too, mostl crawling though.
01-11-2013, 09:05 PM | #6 |
Rock Crawler Join Date: Nov 2011 Location: clarksville,ar
i've run my scx ,with a 6600mah 2s lipo, 40t motor, for a little over 2hrs. and it checked out at 7.5v when i plugged it up to the charger when i got home. depending on how hard you run them, and the mah size of the battery, you can go for a while..you don't need to spend alot on the charger or the batteries..use the search function there should be plenty of info..
I took the plunge - Similar Threads | ||||
took the plunge!! | hoghead5150 | Axial Wraith | 3 | 09-13-2011 06:59 PM |
Took the Plunge! | westcocrawler | Axial SCX-10 | 2 | 04-13-2010 11:20 PM |
Took the plunge | HeavyG | Newbie General | 8 | 04-08-2010 07:53 PM |
Taking the plunge... | Browncoat | Newbie General | 3 | 04-22-2008 07:08 PM |
Take the plunge | bikemikeb | Newbie General | 3 | 06-16-2006 06:14 PM |
