09-10-2013, 07:18 PM | #1 |
Rock Stacker Join Date: Aug 2013 Location: Canada
| How to remove axle gear bearings?
Good day, As the title asks. Do I have to take the gear and that little mounting box apart to remove the outer bearings? I'm talking about once your inside the axle. I really want to clean the bearings as there is some rust on them. Thanks |
09-10-2013, 07:36 PM | #2 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Re: How to remove axle gear bearings?
I'm assuming you're talking about the SCX10 axles? If so, take out the ring gear and locker assembly and then pull the bearings off of the plastic locker housing and the metal ring gear. So, no, you don't have to disassemble the assembly to pull the bearings. Last edited by Lentsnh2012; 09-10-2013 at 07:39 PM. |
09-10-2013, 07:51 PM | #3 |
Thanks for the quick response. Turns out it was rusted on and I broke it taking it off. Good thing I have a full set on order. lol I bought this rig used and all the bearings are rusted so I thought I would take them apart to soak in 3-in-1 oil. Might be able to make something work temporarily until the new ones show up. |
09-10-2013, 08:14 PM | #4 |
Quarry Creeper Join Date: Jan 2013 Location: LP, LA
Get some Evapo Rust. Submerge the rusty parts in it to dissolve/remove the rust. Non toxic. No fumes. Works great. Advance Auto carries it.
09-11-2013, 02:23 AM | #5 |
OK so I just finished re-assembling the front and rear axle. The front bearings were in way better shape. Almost no rust and everything looked new. Is this normal? |
How to remove axle gear bearings? - Similar Threads | ||||
worm gear shims remove or not | love2crwl | Newbie General | 11 | 01-12-2010 11:33 PM |
How to remove inner axle gears without pressing axle pins! | revo-4tec-mike | XTM Crawler | 2 | 03-07-2009 07:11 PM |
How do I remove my knuckle bearings? | BigB_117 | EnRoute Berg | 18 | 03-04-2009 07:19 PM |
