06-01-2014, 08:32 PM | #1 |
Quarry Creeper Join Date: Jan 2012 Location: Central Florida
| Castle BEC question?
Im running the sidewinder 3 combo in a twin hammers and love it. the esc has a 10 amp bec on it, but the stock spectrum receiver only has one port available the bind plug. The third channel is for the shift servo. Can I plug the bec into the bind port? Or is there another way? I do plan on getting a much stronger servo . Any advice would be Appreciated! |
06-02-2014, 08:41 AM | #2 |
| Re: Castle BEC question? |
06-02-2014, 08:30 PM | #3 |
Rock Crawler Join Date: Jan 2008 Location: Lehigh Valley, Pa
Depending on if you get a high voltage servo you may want to power the servo direct from the BEC, otherwise the bi d plug us fine for now.
06-02-2014, 09:43 PM | #4 |
Newbie Join Date: Oct 2013 Location: Gunnison
If you search for bec or servo wiring diagram on here it should pull up harleys diagram on how to directly wire your servo to the bec with a y harness. I use this method on all my rigs and haven't had a problem with brown outs since.
06-03-2014, 07:47 PM | #5 |
Very nice. Thank you! I like the idea of the Y harness.
06-03-2014, 11:11 PM | #6 |
Quarry Creeper Join Date: Aug 2013 Location: Fort Worth
This is the receiver bypass I use for an easy way to directly power a high voltage servo (instead of sending power to the receiver). CreationFab - Plugs Other Receiver Bypass Adapter A high voltage servo may accept power at 7.4 volts while your receiver is often only rated at 6 volts, this is when I would use this type of adapter. If your servo can't handle any more voltage than your receiver, using the bind port on your receiver should work fine. |
06-04-2014, 08:27 PM | #7 |
Just an FYI spectrum ones are good to 9.6 so if you got a hv servo you could put 7.4 to the reciever
06-07-2014, 08:21 PM | #8 |
Seems to be working well. Thanks for all the input. |
Castle BEC question? - Similar Threads | ||||
Castle bec question | squish72 | Electronics | 2 | 07-24-2011 04:32 PM |
Castle BEC question PLEASE HELP! | MRCCRAWLER1.9 | Electronics | 9 | 01-03-2011 09:41 AM |
Castle bec question... | rideordieguy | Newbie General | 6 | 06-12-2010 02:49 PM |
castle bec question... waterproof? | mcreil41 | Electronics | 1 | 01-10-2010 10:28 AM |
Castle BEC Question | dustin keeler | Electronics | 10 | 05-01-2009 12:02 AM |
