08-15-2014, 07:25 AM | #1 |
Newbie Join Date: Jul 2014 Location: Frostburg
| Suspension Help
Hey guys just a quick question on a scx10 4 link front and rear should I use same length pipes and post to match length of front to rear or doesn't it really matter? And the directions I was supplied says to us a upper link mount on front and rear is that ok to do??
08-16-2014, 08:34 AM | #2 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
| Re: Suspension Help
What rig do you have? (that makes a difference because of wheelbase) YES, the upper link mount is the same for the front or rear SCX10 Deadbolt, Recon G6, Falken G6 have a 12" wheelbase and would use the same length links for the front and rear. SCX10 Honcho or Jeep JK have a 12.3" wheelbase and use slightly longer links in the rear. SCX10 Dingo is the shortest at 11.4" and uses even shorter links. |
08-16-2014, 09:08 AM | #3 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
| Re: Suspension Help
So, which rig do you have? If you're not sure you have the links right, put the body on and see if the tires line up with the wheel openings. If they line up you should be good to go. Also make sure your axle is level, if not slightly clocked. |
08-16-2014, 10:29 AM | #4 |
| Re: Suspension Help
I have the scx10 deadbolt.. I appreciate the help problem fixed
Suspension Help - Similar Threads | ||||
rustler suspension arms versus bandit suspension arms... | STEEL_CITY_CRAWLER | Non Crawler RC's | 5 | 08-30-2010 11:05 AM |
suspension help | ryan772 | Venom Creeper | 21 | 05-03-2010 01:08 PM |
suspension??? | kiwi trasher | Newbie General | 1 | 07-13-2007 04:23 AM |
Suspension | revoster | Newbie General | 9 | 04-19-2006 08:31 PM |
Suspension | ComancheCrawler13 | General Crawlers | 3 | 02-05-2006 04:50 PM |
