09-21-2014, 03:56 PM | #1 |
Pebble Pounder Join Date: Apr 2013 Location: Eastern Georgia, USA
| New servo, do I need a BEC?
Yes this is a common question, Yes, I AM searching for the answer while you read this .. But I need a fast answer so I can cancel the order before it ships, if I need to.. so while I am searching for the answer maybe someone can answer it for me . . . I have a 100% stock (electronics) Axial Honcho. I've just been given an Amazon gift card, and searched out and bought a Hitec HS-645 servo. This is a digital servo. What I am reading on their site says not to use their digital servos on Lithium batteries without a 'regulator'? What are they talking about? Oh, I use a 2cell Lipo, forgot to say (edit). Again, my Honcho electronics are 100% stock .. is the BEC and reciever in the honcho sufficient to run the Hitec HS-645 servo? sorry for asking such a well-beaten question, but like I said ... I need an answer quickly enough to cancel the order on Amazon, and while I wait for an answer, I will continue to search for one myself. Michael, "DieCastoms". Edit: Update: As a quick update, the forum search is not returning any search results, at all . . . . I do not know why :/ Last edited by DieCastoms; 09-21-2014 at 04:03 PM. |
09-21-2014, 04:02 PM | #2 |
| Re: New servo, do I need a BEC?
Not really a servo worth buying imo but if you want the most out of your system in would get a bec. Sent from my VS980 4G using Tapatalk |
09-21-2014, 04:28 PM | #3 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
In everybody's opinion!!! I would get a solar 772 for $23 and a castle creations BEC set it to 7.4v (or have local hobby shop do it) & have 415oz of torque & if it dies you want be out of much...$23!!!
09-21-2014, 04:39 PM | #4 |
Quarry Creeper Join Date: May 2014 Location: Burlington, ON Canada
If the ~$25 you'll pay for the BEC is the last $25 in your bank account then no, don't buy it. Otherwise yes, get it. You can't really go wrong in getting a BEC (unless you carelessly overpower your servo). |
09-21-2014, 04:41 PM | #5 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: New servo, do I need a BEC? |
09-21-2014, 04:47 PM | #6 |
3rd sticky down at the top of the page.. No search needed.. "Yes, you you a external bec".. It gets easier to navigate the forum after a while.. |
09-21-2014, 04:49 PM | #7 | |
| Re: New servo, do I need a BEC? Quote:
For the same specs (speed and torque) and components being equal ie. digital, metal gear, coreless, you can spend $23 or $123. What makes them different? What could be so crappy about this solar that it's only $23??? Last edited by GodSpeed999; 09-21-2014 at 04:52 PM. | |
09-21-2014, 04:52 PM | #8 | |
The servo I bought is digital .. it has 168oz/in.@6.0v here is the Amazon page, and below that is the manufacturer's page. Amazon.com: Hitec 35645S HS-5645MG Digital Hi Torque Metal Gear BB Servo: Toys & Games HS-5645MG High Torque, Metal Gear Digital Sport Servo | HITEC RCD USA | |
09-21-2014, 04:58 PM | #9 |
Rock Crawler Join Date: Jul 2009 Location: Victoria Australia
Thats for a 5645 you said you were getting a 645 2 different servo's.
09-21-2014, 05:11 PM | #10 | |
09-21-2014, 05:16 PM | #11 |
now i remember why i do not bother to ask questions on these damned forums anymore . . . . I've been running the truck for two years on the piece of shit stock Axial servo which shorted out to the frame and needs the leads replaced before I can use the truck at all, so *ANYTHING* is better than that, RIGHT? My question is ONLY as follows: AM I GOING TO FRY MY ELECTRONICS without a BEC or can I get away with out one until the next time I can afford to scratch my ass? thanks. |
09-21-2014, 05:25 PM | #12 |
No, you can get away with it.. Not horribly recommended, but you can. |
09-21-2014, 05:32 PM | #13 |
Get this and a bec if you have enough left over. Amazon.com: Solar Servo D772 High Voltage 0.17sec@7.4v 64g Digital Metal Gear: Toys & Games |
09-21-2014, 05:40 PM | #14 | ||
09-21-2014, 05:41 PM | #15 |
09-21-2014, 05:46 PM | #16 |
09-21-2014, 05:47 PM | #17 |
| Re: New servo, do I need a BEC? Oh china made, weaker gears probably, also no parts availability or warranty.
09-21-2014, 06:33 PM | #18 |
so according to that amazon link: Speed @4.8v 0.22 Speed @ 6.0v 0.2 Speed @ 7.4v 0.17 Torque (oz./in) 4.8v 305.8 Torque (oz./in)6.0v 368.35 Torque (oz./in)7.4v 417 Torque (kg/cm) 4.8v 22 Torque (kg/cm) 6.0v 26.5 Torque (kg/cm) 7.4v 30 Length 41.3 Width 21.2 Height 40 Weight (g) 64 Gear Material Metal Bearing Type Dual Ball Bearings Digital / Analog Digital Motor Type coreless apply for Helicopter/plane/boat/car This thing is accurately twice the torque of the Hitec at 6 volt, or is that blown smoke to sell more servos? Does it have a plastic final gear? Can I GET that final gear if/when I strip it out? Is the case going to crack near the output with 'back yard' use? Are the shaft holes/bushings inside going to wear out? The Axial AS-3 servo has been sufficient up until now, but I am adding weight to the front wheels finally, 5 or 6 ounces each, so I thought now was the time to upgrade the steering servo and set the Axial one aside for the eventuality of getting a 2-speed trans . . . . |
09-21-2014, 07:07 PM | #19 |
The Solar D772 is a great servo. Some here even run it at 8v with no problems. All gears are metal. I had two in my wraith for 4ws. It stalls at 2.86A at 7.4v. I will be getting more for future projects.
09-21-2014, 07:08 PM | #20 |
Rock Crawler Join Date: Nov 2011 Location: clarksville,ar
I have a solar d772 in my sons rig...they're not bad for the price, but it absolutely needs a bec to get anything out of it.... also I ran a couple hitec 5645 servos in older scx10's of mine and my sons, with no issues (on 1.9 tires) with a considerable amount of weight in the tires...again they worked fine and never gave me any issues...without a bec on either truck (mainly because I was new to crawling and didn't know about bec's)...
New servo, do I need a BEC? - Similar Threads | ||||
how do i know if i need a new servo and a bec?? | Willyb211 | Electronics | 20 | 06-13-2013 09:25 AM |
servo and bec ? | Barndog Racing | Electronics | 5 | 01-13-2013 10:08 PM |
Help with CC BEC to servo | 99xjlove | Losi Mini-Rock Crawler | 18 | 04-29-2012 01:37 PM |
Servo and bec?'s | BeerMonkeY | Tamiya Clod Buster | 0 | 09-15-2008 09:19 PM |
