01-05-2015, 02:01 PM | #1 |
Rock Stacker Join Date: Dec 2014 Location: tucson
| dual servos on one BEC?
I'm i able to run 2 solar D772's off of one BEC?..say a castle creations 10a or a YEP 20a?..does anyone have s wire diagram for what I'm trying to do?
01-05-2015, 05:56 PM | #2 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: dual servos on one BEC?
Yes
01-05-2015, 07:25 PM | #3 |
Quarry Creeper Join Date: Oct 2014 Location: East
Assuming.... 1, Your BEC is only powering two servos and not the receiver. ESC powers receiver. 2, Both Servos are fed from the same signal, ie...like used in a Traxxas duel Steering servo set and not independent channels. You didn't specify. |
01-05-2015, 09:14 PM | #4 |
Yes the BEC will only be powering the servos...i have a Redcat RS10...i saw a different diagram that shows each servos white wire independently still plugged into the receiver, both red power wires connected to the power wire on the BEC and both black grounds connected to the grind wire on BEC
01-05-2015, 10:14 PM | #5 |
RCC Addict Join Date: May 2011 Location: at home
you can use one bec for the two servos even though they are different channels as in the 4ws of the rs10. be sure to run signal and ground from each servo to the receiver and power lead and ground to the bec from each servo as well. the only reason not to also use the bec for the receiver is if you have set the voltage up higher than what the receiver can handle (over 6 volts in most cases) the quality servos can handle 7 and even 7.5 volts. try to find the specs for the servos you will use though 6 or even 6.5 volts should not be a problem Last edited by cabron; 01-05-2015 at 10:21 PM. |
01-06-2015, 06:15 AM | #6 |
Here's some specs i found on the d772's....Speed @4.8v 0.22 Speed @ 6.0v 0.2 Speed @ 7.4v 0.17 Torque (oz./in) 4.8v 305.8 Torque (oz./in)6.0v 368.35 Torque (oz./in)7.4v 417 Torque (kg/cm) 4.8v 22 Torque (kg/cm) 6.0v 26.5 Torque (kg/cm)
01-06-2015, 05:55 PM | #7 |
The D772 running on 7.4v. stalls at 2.86A, so you're good to go.
01-06-2015, 05:58 PM | #8 |
Is there a specific way i need to hook it up to run it at 7.4v?
01-06-2015, 06:57 PM | #9 |
Use a cc bec to power them. You program the bec's output to 7.4v. Just follow the diagram above.
01-06-2015, 07:09 PM | #10 |
According to the diagram above i splice together the yellow servo wires and plug into the receiver..I've also seen a diagram with each servos yellow wire plugged into the receiver independently (not spliced together) with only the servos red wires spliced together and the black wires spliced together...on a RS10 wich way should the yellow wires be plugged in?...stock configuration has each servo plugged into the receiver separately.
01-06-2015, 07:16 PM | #11 | ||
| Re: dual servos on one BEC? Quote:
dual servos on one BEC? - Similar Threads | ||||
Need help with dual ESC, dual servo, bec wiring | mudboggin3 | Electronics | 3 | 08-21-2012 10:23 AM |
dual bec with dual servos? | t-oda | Electronics | 10 | 01-22-2011 10:35 AM |
wiring diagram for dual esc's, dual servos, bec, and one battery??? | jedsled | Tamiya Clod Buster | 6 | 11-13-2008 07:36 AM |
Dual Digital Servos and ESC BEC Problems | ap714 | Electronics | 0 | 02-04-2006 06:45 PM |
