07-08-2015, 04:12 AM | #1 |
Newbie Join Date: Jul 2015 Location: Fletcher
| Crawling with a yeti??
I purchased a new yeti (my second rc) I also got 2 scx10s for my sons, so I tried crawling with them. It's the rtr so I went 3s (Because it says you can) I had a thermal before I got through 1 battery,so I did some research. I went to a 14/68 pinion/spur checked and regreased the axels installed a mip rear drive shaft. That seemed to help,but today the thermal went nuclear and my esc caught fire and up in smoke she went. So my question is has anyone been able to make a yeti crawl and how?
07-08-2015, 05:09 AM | #2 |
RCC Addict Join Date: Oct 2014 Location: UK
| Re: Crawling with a yeti??
You will need the SSD 2 speed kit to get crawling speed as it has a low ratio first gear: 2 SPEED TRANSMISSION CONVERSION KIT FOR YETI |
07-08-2015, 07:16 AM | #3 |
Quarry Creeper Join Date: Oct 2010 Location: Nashville TN
a good sensored system is in your future too. castle mamba max pro and a tekin roc412 3100 or pro4HD 3000 for 3s use.
07-08-2015, 08:17 AM | #4 |
I'm already thinking the 2 speed is the way to go. And sensored sounds good also.
07-08-2015, 08:19 AM | #5 |
And thanks
07-11-2015, 04:03 PM | #6 |
Rock Stacker Join Date: May 2015 Location: Riverview-FL
Im fairly new here too but Id also think you'll want to lock up the front end with one of the many kits out there.
07-12-2015, 06:41 PM | #7 |
I did lock up the front diff by filling it with jb weld that seems to work good. Still waiting on my replacement esc but I think I'm going to 2c until rpp gets the 2 speed upgrade back in stock
07-21-2015, 07:32 PM | #8 |
So an update. I replaced the esc with a new ae3 installed a 10 amp castle bec,a castle fan on the esc and only got 90 degrees on a 20 minute slow crawling run. Happy with that though still nervous. And also had to replace the receiver as it got fried by the esc
07-21-2015, 08:35 PM | #9 |
I wanna be Dave Join Date: Jul 2010 Location: Toronto
You don't need a 2 Speed kit to make a slow Yeti. I run 12T Pinion and 68T Spur on a Sensored 2100kv MMP and it'll crawl all day long. I don't even run the fan on the ESC.
07-25-2015, 08:25 AM | #10 |
| Re: Crawling with a yeti?? I agree I'm just trying to do it with the rtr motor/esc. With the bec,esc fan and a 14t/68t I've been able to keep the esc under 100 degrees but the motor is getting pretty warm,so I'm going to try an 11t pinion.
Crawling with a yeti?? - Similar Threads | ||||
Yeti, Set, GO!!! FastEddy Bearings for the Axial Yeti | FastEddy | Axial Yeti | 13 | 04-21-2015 07:33 AM |
SCX10 vs. Yeti: Casual crawling & Trailing? | macnkitty2002 | Axial Yeti | 27 | 03-15-2015 05:41 PM |
Ultimate Yeti Crawling and Bashing! | téosrc | Axial Yeti | 0 | 11-17-2014 01:53 AM |
