Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: TLT Shopping List
Old 01-06-2007, 03:16 PM   #1
Smile TLT Shopping List
Need advice --
Say you got some extra cash from Santa . . . . . which servo, which tranny, which esc, which motor, which battery and which radio would you get to build the ideal TLT based crawler? Do I cannibalize somebody's Stampede off e-bay and hope for the best? or should I pick up each piece seperately? Looking to build a rig that does it right.
rok ej is offline   Reply With Quote
Old 01-06-2007, 03:18 PM   #2
I think you should look around and do some research on your own. This site is here to answer questions, not build your crawler for you.
kerosinek is offline   Reply With Quote
Old 01-06-2007, 03:36 PM   #3
He's right, nobody knows "the best" way to build a TLT crawler. I just picked one up and built it mostly stock (other then wheelbase and tires) I quickly learned the stock trans SUCKED and the high COG (center of gravity) held me back on the steep stuff. I started modding and buying and reading and more modding and more buying ect.ect.ect. If you start with the stocker then start modding a little at a time you will have a good crawler pretty quick. The most important thing is that your happy with it, don't build to please others here (or anywhere else) Just build it drive it and learn! I now have 4 TLT trucks and 1 clod and have got my Dad and Uncle into it with there own TLT's and no two rigs are the same, something is different about every one. So good luck and have fun!
racerx is offline   Reply With Quote
Old 01-06-2007, 10:16 PM   #4
revin9k's Avatar
if you want to get an idea of what stuff is the best check out peoples rides here...National Comp Rigs.......
revin9k is offline   Reply With Quote
Old 01-06-2007, 10:34 PM   #5
TLTCrawlin's Avatar
which servo
645 from tower
which tranny
Pede trans, from RBGerrish (vendor section~Tammies Hobbies)
which esc
XRS from tower, push into brake, then let go and push back for reverse (better than a long delay though)
which motor
55t
which battery
If a comp rig IB1400, if a fun crawler stick pack 1500
TQ from ebay, or something futuba from tower
Just buy a pede trans
Should I pick up each piece seperately? Looking to build a rig that does it right.
Yes.
Just noticed your about 3 1/2-4 hours from me! We got quite a few people in Tri-Cities!
TLTCrawlin is offline   Reply With Quote
Old 01-10-2007, 10:53 PM   #6
Thanks for the help! I'll go do some research and get started!
You're right -- we're not far from each other!
