03-27-2016, 02:17 PM | #1 |
Quarry Creeper Join Date: Jul 2011 Location: ireland
| ar60 vanquish scx10 link mount question
was wondering does the vanquish scx10 link mounts fit on the ar60 axles. i got some gcm metal heads axles a while back that i havent used yet to fit the ar60 link mounts but want to fit them on my ascender chassis
03-27-2016, 08:35 PM | #2 |
Newbie Join Date: Aug 2015 Location: Mesa, AZ
| Re: ar60 vanquish scx10 link mount question
No, AR60 axles don't have the 3 holes on top that all the ax10/scx10 link plates use to attach to the ax10/scx10 axles. check out DLUX FAB he sells a sporty truss for the AR60 that relocates the servo and has multiple mounting options for upper 4 link placement. if you still need a plate to mount battery/esc, check out my build thread for my solution, its way over kill, but shows you whats possible.Blue Inside You can also see where I installed an ax10 battery plate on a AR60 axle in the rear, and it not centered.
03-28-2016, 04:34 AM | #3 |
sorry should have specified it was the lower link mounts i was talking about VPS06723 VPS04460 |
ar60 vanquish scx10 link mount question - Similar Threads | ||||
AR60/Wraith Servo/Truss/Link mount | Erik D_lux | Axles, Trannys, T-case | 118 | 03-26-2018 01:30 PM |
AR60 axle truss/link mount not centered | TacoCrawler | Axial Wraith | 46 | 03-28-2016 11:20 PM |
vanquish wraith link on ar60 axle with vanquish xr10 knuckles? | T3rry | Axial AX10 2nd-gen | 2 | 04-28-2013 06:11 PM |
