11-19-2016, 09:16 PM | #1 |
Newbie Join Date: Nov 2016 Location: Singapore
| Locked Diff on the rear vs "Active" Diff
Hi, Apologies as I am still new in Crawler. I am looking at getting a Vaterra Twin Hammer, and as I was going through the online manual first. I noticed that the Rear Diff is a Locked Diff, vs a normal Active, moving Diff. Apologies for the term used. Is there any reason why the rear need to be in locked mode ? Is there a term for "Active" diff, does "Open" Diff means moving, working diff ? Many thanks for any guidance. |
11-19-2016, 11:15 PM | #2 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
| Re: Locked Diff on the rear vs "Active" Diff
Traditionally crawlers diffs are locked to aid with traction. A locked diff is a essentially a spool that ties the two axle shafts directly together. The Active diff gives the vehicle a Open diff. Not sure why it is called active? perhaps they consider that you can adjust the oil thickness to make it act more like a limited slip. This video explains the types. https://www.youtube.com/watch?v=gIGvhvOhLHU Personally I would recommend locking it for rock crawling, backyard bashing or otherwise. Only time I would leave it open is on the track or street. |
11-20-2016, 01:51 AM | #3 |
Thanks for the note. I will certainly like to use a Open Diff on the Rear with thick oil to control the "slip" given that I will likely to run it on a road surface as well. |
Locked Diff on the rear vs "Active" Diff - Similar Threads | ||||
has anyone locked the rear diff on an XL yet? | skybolt | Axial Yeti XL | 11 | 07-18-2015 09:30 AM |
To "diff" or not to "diff"-that is the question. | The Bug | Vaterra Twin Hammers | 13 | 02-25-2014 11:09 AM |
Monster truck - locked rear diff? | 701 Technique | Newbie General | 2 | 08-29-2012 06:40 PM |
Locked the rear diff... | XFACTOR | General Crawlers | 9 | 07-07-2004 09:02 AM |
