02-13-2017, 09:40 PM | #1 |
Newbie Join Date: May 2015 Location: Singapore
| Stretching SCX10 Wheelbase to fit New Bright JK Body
Hi, first I'd like to introduce myself as I am still quite new to the forum - Dirk here from Singapore - not new to RC, but fairly new to crawlers. Now, I have a RTR SCX10 with a 313mm wheelbase right now and just bought a New Bright Jeep body which I would like to add to my SCX10 chassis. I know that you have to extend the wheelbase to roughly 330mm (13 inch). But so far I couldn't find the exact answer on how long the links should be and hope you guys can help. Also, do I only stretch the rear or both front and rear? I would like to use the Axial aluminium link kit with spacers, 3 link with panhard in front and 4 link rear using the rod ends that come with Axial. Could you help me in understanding which link size in mm I should use for front, upper and lower as well as rear upper and lower using Axial rod ends? Thanks so much! Last edited by derdirk; 02-13-2017 at 10:09 PM. |
02-15-2017, 10:02 AM | #2 |
| Re: Stretching SCX10 Wheelbase to fit New Bright JK Body
That's a difficult answer, basically put the chassis and body in front of you, measure, eyeball etcetera, make some longer links and test fit. You'll probably end up re-making some links to get it just right. You can get away just lengthening one end, but may be beneficial to lengthen a bit at both ends, depending on the front/rear weight bias that you want to achieve. According to your measurements, you need to stretch the chassis wb by 17mm (one inch = 25.4mm) probably fine to just stretch the rear links. Keep us updated and post some pics. |
02-15-2017, 05:19 PM | #3 |
Newbie Join Date: Feb 2010 Location: TYLER
can you not just subtract 313-330=17 then divide by 2 and get 8.5 mm longer on each link or does that not work in buildling links curious myself |
02-15-2017, 05:29 PM | #4 |
Newbie Join Date: Jan 2011 Location: San Diego
I kept the front stock and extended the rear. I am running ax10 2.2 wheels and tires and was able to fit them in the wheel wells without modification with a 13.4" wheel base Here's a pic of the trailing arms I made. Tacked up some tig filler rod and threaded on some end links Hard to read it properly but it is around 13-3/8" wheel base Tires will fit wheel wells without body modification Or you can do slight trimming to the back of the rear fenders and cut the nose off the front fenders to achieve a more scale looking body height As you can see you can get plenty of flex Last edited by THX_138; 04-30-2017 at 10:12 PM. |
02-15-2017, 09:04 PM | #5 |
@andyjr: was thinking the same, just equally split between front and rear but wasn't sure it make sense. @Piranha_GT thanks for your pictures and feedback. Was actually hoping I could realise this with the stock links and just add some spacer to upper and lower links - tricky part really is to figure out how much to extend each side. Also, you have to extend both upper and lower links right? |
02-15-2017, 10:15 PM | #6 |
Pebble Pounder Join Date: Nov 2016 Location: USA
Ive used these spacers to experiment with on my scx...they can be obtained on ebay too. Not sure who else sells 'em. http://gonitrohobbies.com/J80035/ |
02-15-2017, 10:30 PM | #7 |
@derdirk come to think of it I think I actually used the rear links on the front, so it did actually push it forward a bit. Sorry for the misinformation Yes the upper links need to be extended as well You will also need to lengthen the driveshaft. I just bought another set and spliced it together as seen in first pic Last edited by THX_138; 04-30-2017 at 10:06 PM. Reason: Merge, posts minute apart |
02-16-2017, 12:15 AM | #8 |
Thanks gain Prianha_GT. I think I will just play with some spaces front and rear till i reach a decent wheelbase that it make look good. Once my body arrives and i have time to adjust I will post some pics as i progress. Found a few information on the link size, but they seem to be all different from each other - here are some examples I have found: Hole to hole Front 120mm / 110mm Rear 145mm / 135mm Front: upper: 135mm lower: 145mm Rear: upper: 130mm lower: 133mm Will be playing around and see which one works best. My body finally arrived and I had time to look into the wheelbase. For now I have added 2x 4mm spacers on the lower links (rear) and 1x 5mm spacers on the upper links (rear) and left the front stock - I am using the axial standard aluminium link kit with the original rod ends. For me it seems to look pretty ok - Now I just need to work on the body!! Sent from my iPhone using Tapatalk Last edited by THX_138; 04-30-2017 at 10:27 PM. |
02-27-2017, 09:27 PM | #9 |
Rock Crawler Join Date: Feb 2017 Location: Northern Virginia
That thing would look almost PERFECT on a Wraith. Especially with the 2.2's.. whew! That red J/K would look sweet on one! It does look good on your extended SCX10 too dont get me wrong I just thought about all what was written earlier in the thread.. |
03-01-2017, 10:41 PM | #10 |
Out of curiosity, do you have pics of the spacers/ links?
03-02-2017, 08:02 PM | #11 |
Here you go: Sent from my iPhone using Tapatalk |
03-05-2017, 09:13 PM | #12 |
| Re: Stretching SCX10 Wheelbase to fit New Bright JK Body |
03-05-2017, 11:36 PM | #13 |
I bought them at rpphobby - just search for axial spacers - they come in multiple sizes. I'm sure other hobby stores have them too. Sent from my iPhone using Tapatalk |
03-06-2017, 06:36 PM | #14 | |
| Re: Stretching SCX10 Wheelbase to fit New Bright JK Body Quote:
Perfect, I think I found them. Thanks for that. I have the junfac ones but the actual axial branded ones look much better imho. I didnt know they made them. | |
03-24-2017, 08:19 AM | #15 |
Worked a bit on the body the last couple of days and wanted to share a picture: Sent from my iPhone using Tapatalk |
03-24-2017, 08:56 AM | #16 |
The Jeep's looking great! Keep it up! On a side note, theres a rear bumper from rc4wd (Z-S1297) that would look sick on that thing! Might not be your cup of tea but... Turns out it's a real bumper/tire carrier. Here it is on a jeep that was for sale somewhere in TX... Also, I got my spacers. Thanks again. Last edited by CR4NK; 03-24-2017 at 09:04 AM. |
03-24-2017, 12:40 PM | #17 |
RCC Addict Join Date: Feb 2017 Location: Surprise
03-25-2017, 04:20 AM | #18 | |
| Re: Stretching SCX10 Wheelbase to fit New Bright JK Body Quote: Pretty cool - but with them you can't reach the wheelbase you need for the NB body since max length is 315mm. Sent from my iPhone using Tapatalk | |
04-09-2018, 07:16 AM | #19 |
Newbie Join Date: Apr 2018 Location: Columbia
I known this is an old thread but can anyone give me tips on paining these NB bodies?
Stretching SCX10 Wheelbase to fit New Bright JK Body - Similar Threads | ||||
adjusting SCX10 wheelbase to fit other bodies | ericinMD | Axial SCX-10 | 13 | 12-17-2015 01:41 PM |
Will a Vanquish link set meant for a 12.3" wheelbase SCX10 fit a 12" wheelbase? | Derekuda | Newbie General | 1 | 08-10-2015 06:10 AM |
Converting SCX10 to fit New Bright JK Body? | deadbase | Axial SCX-10 | 1 | 03-01-2013 04:48 PM |
Stretching wheelbase on my SCX10 TR | Davenow | Axial SCX-10 | 5 | 02-15-2010 11:04 PM |
Stretching Wheelbase ???? | JeepDriver | Tamiya TLT Crawlers | 19 | 09-08-2008 02:11 PM |
