11-20-2017, 09:51 PM | #1 |
Pebble Pounder Join Date: Jul 2016 Location: Ne pa
| Comp rules
Hi all ive only been involved in rc rock crawling for about a year but have been involved in rc for a while. The question i would like to pose is why do comp rules shoot the sport in the foot by not helping those mfg’s that help us and chaseing away newcomers with a rule set that caters to chineese manufactures of cheep plastic toys? If you try to follow sorrca rules with another than hard body you must have almost everything else on the score sheet to make points but if you buy a chineese toy body (and even in some clubs that complain about flexability of lexan or polycarbinate leave those hardbodys fastened with velcro so they pop loose if you hit something) it makes it easy to max points? Shouldnt we be striving to make it at least somewhat easy for new people to compete on an equal level without going nuts on spending for braging rights?
11-21-2017, 11:27 AM | #2 |
Rock Crawler Join Date: Jan 2010 Location: [loh-key-shuhn]
| Re: Comp rules
I'll share my opinion, and only my opinion... Competitions of any kind is not the place to start in any hobby. A new person that starts in a comp situation strait out of the gate (pun intended) will not have a good time. I'd argue that at any level - 1:1 racing or RC stuff. In the scale crawler world, I'd recommend starting out with a local group that does not compete, but just goes out to have fun, more like trail rides. No pressure to perform or hurry up or not hit stuff. Just have fun. Once the new person becomes "less new" and more versed in scale crawlers, AND has an interest in competition, then they can find opportunities to compete. Will they be competitive? They can with good driving skills and a good rig. Does the rig need to be thousands of dollars or hand built? No. I have seen stock, out of the box, scale crawlers finish high on the driver list because the truck was capable and the driver could drive. Scale points allow you to be a less good driver. For example: if someone has 10 more scale points than you, you need to hit one less gate than they do. If the other driver has max points and consistent clean runs, then they are on a higher level than you. So, to answer your question, "Shouldn't we be striving to make it at least somewhat easy for new people to compete on an equal level without going nuts on spending for bragging rights?" No. It will cost you to compete whether it is time and/or money. Competition isn't cheap or (in my opinion) entry level. There are two kinds of folks in the world, those that like to compete and those that don't. Those that do, understand what it takes to get to competition level; those that don't, from my experience, just wine about it. |
11-21-2017, 11:52 AM | #3 | |
RCC Addict Join Date: May 2015 Location: Price Twp.
| Re: Comp rules Quote:
Yes there should be a set of rules that cater to a box stock truck allowing access to, on a beginners level, comps. (my opinion) Unfortunately it seems that the prominent rule making body doesn't share that opinion. From the outside looking in, they have their heads so far up their collective ars, that it makes entry into comps a very overwhelm and expensive proposition. If you want to see that first hand visit their FB page. I would disagree with your equal level statement. Those people who go above and beyond in making a scale truck according to the rules they comp by should not be judged on the same level as if you buy a deadbolt and show up the next day. | |
11-21-2017, 07:54 PM | #4 |
Pebble Pounder Join Date: Aug 2014 Location: Middle
| Re: Comp rules
I think the original intent of scale rules was to award those who took the time to scratch build interiors and scale items and run hard bodies. Also if your import Walmart body comes un velcro'ed then you have to take a repair penalty because it no longer fits the rules. You can build a full points truck with a lexan body but its easier with a hard body. I have both ends of the points race with my trucks and if i comp a lower points truck than i have to accept i might lose due to scale points. You should definitely go to comps! The driving time will always improve your skill and you can gradually build scale points to be more and more competitive. Just my 5 cents
11-21-2017, 10:08 PM | #5 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
| Re: Comp rules
Comps are a lot of fun. They will make you a better driver by pushing you and your truck to the limit, as well as give you the opportunity to watch more experienced drivers. Maybe if you have enough other newbies you can talk the people putting on your local comps to have a newbie class. As for points, ALMOST everything that you do to add points is detrimental to the truck's performance. Hardbodies weigh more than lexan and put the weight up high. Same goes for roof racks, roll cages, spare tires, pull pals, chassis mounted servos, etc. You have to decide if those few points are worth adding a bunch of weight up high or if you really want to spend that extra money or time putting little scale touches on your truck. I'd love a box stock RTR class, but it looks like it would be up to local groups to set it up. The only mod allowed would be to put on the battery connection of your choice on the ESC. That would be fun because it would be all about the driver. |
11-22-2017, 07:46 AM | #6 | |
11-22-2017, 08:24 AM | #7 | |
However even as I am moving my rigs toward more points I have notice some of it add advantages. I think my forward mounted transmission and transfercase has definitely improved my performance . The rig likes to keep wheels on the ground when climbing and breaking over a rock. At times properly set up leaf springs are not a disadvantage either. | |
11-22-2017, 09:47 AM | #8 | |
| Re: Comp rules
I like the rules the way they are because they push you to build a good rig and play the game with points. Is it worth the points to put the servo on the chassis or are you better off keeping that weight low on the axle? A stock RTR class would probably just be something that you would have to set up with your local club. If enough of you are interested, it could possibly happen. I don't think SORRCA is going to make a set of rules for it (like class zero). Quote:
Some mods like the forward mount motor with transfer case do get points and improve performance, but they still have a trade off. Now you have more parts to break and you have to figure out how to mount your battery and electronics. | |
11-22-2017, 10:06 AM | #9 |
| Re: Comp rules I have to disagree with the weight thing my trx is heavier than some guys scx with hard bodies and preforms better i think the weight thing comes down to tire and suspension tuneing more than anything and i think if you had to run sliders it would kill the flex argument against polycarb or lexan bodies
11-22-2017, 10:26 AM | #10 | |
Lexan bodies flex, bend and deflect giving them an advantage over hard bodies. For that matter plastic slides do the same. Your never going to convince anyone that your jeep body deserves hard body consideration. | |
11-22-2017, 10:44 AM | #11 | |
11-22-2017, 10:46 AM | #12 | |
11-22-2017, 10:55 AM | #13 |
| Re: Comp rules
Ive added weight all over the place to note changes if this is the priority the trx is a poor choice because of the portals because everything must be higher to give them clearance
11-22-2017, 11:17 AM | #14 | |
Now, now Solo1 don't get your panties in a bunch. Its not my fault I know who you really are, and am taking advantage of that to troll you a little bit. in good fun of coarse. What you fail to understand is that having the coin is not what it takes to make a good rig. Those guys with rigs you perceive as being funded by deep pockets are in reality rigs with years of work put into them. With that comes a good knowledge of how the rig will react on the rocks and knowledge of tuning. There is absolutely no rules that stops you from running a less then pointed out rig and going out and having some fun. You wouldn't get nor deserve bragging rights as a less then pointed out rig just does not have the handicap that a hard body rig has. So you really can't have it both ways. Either you want to complete against other drivers based solo on skill. Or you want to compete against drivers with skill and the ability to set up a rig the right way, which will involve deep pockets. Even going box stock, do you think it is fair that your $450.00 traxxas using unlocking diffs and portal, should compete against a stock scx10? You don't consider the extra money for the portals to be a monetary advantage. I'm not trying to correct you or put you down, but you have this idea of fairness in your mind, or lack of fairness, that is not allowing you to see past it. | |
11-22-2017, 11:29 AM | #15 | |
As for prices, go piece together an Axial JK Rubicon body. Its over $80 for all the screws, cage, body, flares. You can get hard bodies for less than that (if you don't buy all the small parts like hinges and bumpers that go with it) As for the other deep pocket comment, a crappy driver with an expensive rig is not going to beat a good driver with a mild build. We had guys with close to stock SCX10s beating highly built rigs here last year. | |
11-22-2017, 11:37 AM | #16 |
| Re: Comp rules I should have my hands on another TRX-4 here shortly. I'm going to see what they are capable of. I'll be eliminating at least the rear locker and most likely the 2nd gear.
11-22-2017, 12:04 PM | #17 |
| Re: Comp rules
Ok so i understand some of these comments and some are true to an extent but here is an example of what im trying to get at the trx is top heavy and heavier than an scx from the start it has some advantage oof the portals but is at a disadvantage because of them also because everything must ride higher up and farther back. But at any rate i did my first comp at the northeast national and finished 13 out of 26 but i was giving up 20 points per course i cleaned the first 3 courses and bumped a marker on the last course. If i had full points i would have finished 2nd. To make 60 points with a stock trx i would have to add almost everything else on the scoring sheet which i did but it put my trx over 12 lbs and was not very competive in that form. Im not looking for a handout but to me it seems that te amount of points you get for a hard body is not in line for the amount of points you get for everything else I seems to me that to have a competetive vehicle you must run a hard body or accept that you wont win
11-22-2017, 12:21 PM | #18 |
| Re: Comp rules
A guy I used to crawl with had a lexan XJ body on an scx10 chassis that was a full points C2 rig and was very competitive (and heavy) both locally and at a national SORRCA event. He had a proper 2 row interior with full cage and cargo area plus drivers to compensate for the hard body points. On a TRX4 you could run a 2 row interior plus rear cargo area. I don't agree a hardbody is a must to point out or be competitive, a well laid out and tuned rig you trust is best. That's badass you had a good time at a comp!
11-22-2017, 12:26 PM | #19 |
Rock Crawler Join Date: Feb 2006 Location: Where the foams are always wet
| Re: Comp rules |
11-22-2017, 12:33 PM | #20 |
| Re: Comp rules
solo1, you are a few years behind the curve. The scale comp scene has evolved past where you are starting, especially at a national level. My first national comp opened my eyes. However, I was at the other end of the spectrum with a maxed out truck that did not perform. I learned a lot from that experience. I went back the following year and finished two points out of third place with a totally different truck. Where would everyone else have finished if you apply your methodology to everyone's scores? Sounds like you are a good driver. Now work on getting your truck where it needs to be with points. That is the next step in becoming more competitive. You have seen it first hand. Many of the podium finishers understand that to be competitive, you start the day with max points. Don't ask for the rules to change and adjust for you; adjust to the rules like the drivers that finish on the podium have done. |
Comp rules - Similar Threads | ||||
comp rules | DEX | South Carolina | 1 | 09-02-2011 12:14 PM |
Comp rules if I chose to Comp?! | RickM | Axial AX-10 Scorpion | 11 | 02-25-2010 09:56 PM |
comp rules | lobi1kanobi | General Crawlers | 1 | 07-15-2009 09:54 AM |
2.2 comp rules | Robb8 | Newbie General | 1 | 12-22-2008 07:48 AM |
1.9 Comp rules | Nitro_Geezer_UK | General Crawlers | 2 | 01-04-2008 09:37 AM |
