03-17-2018, 02:55 PM | #1 |
Rock Stacker Join Date: Mar 2018 Location: Born in FL, stationed in Cali
| First crawler, First post, first question
Hello everyone and thank you for having me. just picked up my first crawler after retiring from years of flying helicopters because flying fast and aggressive 3D style got VERY costly So I just got a SCX10 II Honcho RTR today and already took it crawling. love the truck but I noticed the back right tire has a pretty pronounced wobble to it. I checked and it is not the axle or rim. is there anyway to "reset" the shape on the tire? I messaged the tire to ensure that the foam itself was not bunched up in some weird way causing the wobble. I appreciate any help |
03-17-2018, 03:01 PM | #2 |
Rock Crawler Join Date: Feb 2012 Location: Michigan
| Re: First crawler, First post, first question
Not unless you are willing to bake it off and re-glue it. My guess is that it was not aligned correctly when it was glued. These trucks are slow enough that it doesn't make a difference if the tires wobble. You should have seen my first attempt at cutting out the bead of some 2.2" tires and gluing them onto 1/8th scale tires. LOL
03-17-2018, 03:10 PM | #3 |
I don't mind baking them off. I will be getting a set of bead locks soon enough.
03-17-2018, 08:41 PM | #4 |
Most of the time you can massage the foam and get rid of the wobble and for the most part these tires will center themselves as you drive them. But if massaging does not work then you may need to unglue the tire. Do a quick youtube search for "ungluing RC tires", there are dozens of methods of removing tires. To be honest, if you plan to install bead locks soon, I would not waste my time on these wheels/tires. Just consider some aluminum bead lock wheels and new tires your first upgrade. BTW, Welcome to RCC! Last edited by Inspector86; 03-17-2018 at 08:47 PM. |
03-17-2018, 10:53 PM | #5 |
Newbie Join Date: Dec 2011 Location: Here for a good time not a long time
Can't go wrong with a Scx10.
03-18-2018, 09:59 AM | #6 | |
| Re: First crawler, First post, first question Quote:
03-26-2018, 04:48 PM | #7 | ||
When the truck is not in use, store it off the tires, a block of wood, an RC specific stand (there are many brands and types), or something similar will help keep all four tires round and the foams not prematurely softened/squished up. | ||
03-26-2018, 05:18 PM | #8 |
The foams will probably wear in over time with use and the wobble should become less pronounced. At the speed these things go, the wobble is just more of an eye-sore than any actual problem.
First crawler, First post, first question - Similar Threads | ||||
Replying to a post question. | ShowMeTJ | Comments, Suggestions, and Help | 1 | 04-03-2016 08:39 AM |
post question | jim_w | Alabama | 1 | 07-17-2013 11:35 PM |
First Post, and question already :/ | rogue1series | Axial SCX-10 | 11 | 04-01-2013 02:16 PM |
Question About post | cameraman | Comments, Suggestions, and Help | 2 | 03-01-2012 01:04 PM |
