Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Help with Gen 7...
Old 06-24-2018, 08:33 AM   #1
Default Help with Gen 7...
Newbie... recently purchased a Redcat Gen 7. 5 minutes in I broke a steering arm. Ordered new ones. Broke almost at once, and broke an axle. Ordered the fancy aluminum steering arms, high caster mounts and CV axles. Got 1/2 a batteries use and broke another axle...
I looked and didn't see anything in search about the axles for this truck, so I am asking for some help. I get that this is probably my fault as a rookie driver; however, I have improved things and they don't seem to hold up. Did a lot of 1:1 rock crawling and never broke like this, so... Does anyone make stronger axles for this thing????
Thanks in advance.
Pat
pearing is offline   Reply With Quote
Old 06-24-2018, 09:12 AM   #2
Default Re: Help with Gen 7...
Check out the redcat crawler sub forum lots of info.
RCCrawler Brand Specific Tech - Redcat Crawlers at RCCrawler.com
hillbillyrc is offline   Reply With Quote
Old 06-24-2018, 11:56 AM   #3
Yep... found it right after I posted this.
Old 06-25-2018, 12:45 AM   #4
Thanks, hillbillyrc! I'll check out the link as well.
Vinnymuto is offline   Reply With Quote
Old 06-25-2018, 10:54 AM   #5
Moderator
It sounds to me like something is bound up, or your servo end points aren't set correctly and the servo is putting a ton of stress on those parts.
Jim85IROC is offline   Reply With Quote
Old 07-08-2018, 09:57 AM   #6
I believe that the stock axles with the T cup were binding. I went to the Redcat CV style. These also broke. It also stripped out the plastic locker... all on the left front. I have since put in a hardened steel locker for the SCX 10 (cannot remember the name but found it through a search for on the Gen 7 forum) with modified Redcat CV's. Have now gotten a whole 1/2 hour straight without a mechanical up front! The Redcat axles are bound to fail but I am looking at some Vanquish VVD axles...
Old 07-08-2018, 12:47 PM   #7
I'm glad I haven't wasted money on the redcat stuff for my Everest axles. I just went ahead a got the axial parts right off the bat.
Help with Gen 7... - Similar Threads
xmod gen 1 motor in gen 2 car RootBreaker Micro Scale Rigs 1 08-18-2014 08:40 PM
RS Gen II and 4s? 65BAJA Electronics 7 04-02-2014 07:16 PM
gen 1/4 Pegasix General Crawlers 3 09-16-2006 09:48 AM
