10-04-2018, 10:50 AM | #1 |
Pebble Pounder Join Date: Oct 2018 Location: northen ohio
| axial stoch shock upgrade, dosent exsist
does anyone know where to get JUST the lower cap? (see pic) Sent from my SM-N910V using Tapatalk |
10-04-2018, 11:26 AM | #2 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
| Re: axial stoch shock upgrade, dosent exsist
I cant recall anyone selling just that upgrade part for Axial's shocks, but honestly, your best bet is to upgrade the whole shock. They have far more problems than just that cap.
10-07-2018, 06:27 PM | #3 |
Newbie Join Date: Jun 2018 Location: Downriver
| Re: axial stoch shock upgrade, dosent exsist |
10-07-2018, 07:02 PM | #4 |
Rock Crawler Join Date: Feb 2012 Location: Michigan
10-14-2018, 07:37 AM | #5 |
Dual SMT10 shocks!! seems to not roll over as much, but i need a lighter weight oil, as 20WT is too hard. The white look on the plastic is a NON-STICK coating. I'll coat the shocks next, as its nice when NOTHING sticks to the truck. mud and such just blasts off with a burst from the air compressor. Sent from my SM-N910V using Tapatalk |
10-14-2018, 07:41 AM | #6 |
everyone has there own prefrence for motors, and i really like the 9kv in this truck. The motor has long legs, but geared right, its a perfect crawler. I can go slower than my kids and they have 19t brushed motors. Sent from my SM-N910V using Tapatalk |
10-14-2018, 07:45 AM | #7 |
tip for anyone looking or needing a easy shock build/fix. 2.5mm shim on the TOP of the 2stage pistons can allow them to actualy work. upper shock shaft pic has the shim, while lower is stock with NO shim. Sent from my SM-N910V using Tapatalk |
10-14-2018, 07:51 AM | #8 |
Team associated shock (2.5mm)washers Fit the best in Axial's shock as they are a hair smaller and dont contact the shock pistons. Sent from my SM-N910V using Tapatalk |
10-14-2018, 07:54 AM | #9 |
tamiya damper bushings keep the upper cap from leaking and also help bound/rebound. I glue them in with a tiny penpoint of CA. ( rubber CA is my personal fav) Sent from my SM-N910V using Tapatalk |
axial stoch shock upgrade, dosent exsist - Similar Threads | ||||
AXIAL shock future upgrade? lower shock cap | mprudic0404 | Newbie General | 0 | 10-02-2018 09:24 PM |
Stoch Wraith Issues | Chesebro | Axial Wraith | 4 | 06-23-2013 10:40 PM |
i know this dosent belong here but... | bignick3674 | Michigan | 12 | 03-17-2010 04:10 AM |
axial scorpion shock upgrade | davosfam | Axial AX-10 Scorpion | 1 | 12-04-2009 04:39 PM |
