06-23-2013, 06:33 PM | #1 |
Pebble Pounder Join Date: Jun 2013 Location: Northridge,Ca
| Stoch Wraith Issues
Having a problem were The im loosing reception between the Rx and Tx, maybe no more than 10ft away.. Could it be a failing servo? Ive seen bad servos make money glitches before.. Thats why Im blaming the servo!! I highly doubt the rx or the rx are bad.. Suggetions before I dump $50 on a new servo? |
06-23-2013, 06:55 PM | #2 |
RCC Addict Join Date: Feb 2012 Location: Ca.
| Re: Stoch Wraith Issues
Does the throttle work at more than 10 feet away? If so, probably the servo. If everything is still erratic, unplug the servo, raise the wheels off the ground and try the throttle at more than ten feet away. If the throttle is erratic, then probably the RX. Is this a new problem?
06-23-2013, 07:03 PM | #3 |
No once 10 ft apart nothing works til I start walking closer to it..
06-23-2013, 09:12 PM | #4 |
Pebble Pounder Join Date: Dec 2011 Location: Ohio
That is an rx tx problem. Contact axial and they can help you wih replacement parts.
06-23-2013, 10:40 PM | #5 |
Stoch Wraith Issues - Similar Threads | ||||
Wraith servo/winch clearance issues | memphis_m3z | Axial Wraith | 0 | 06-09-2013 05:32 PM |
Having some Wraith issues! | AXLE 69 | Newbie General | 10 | 04-08-2013 07:37 PM |
wraith issues | evil_monkey | Axial Wraith | 10 | 03-30-2013 06:35 PM |
Wraith receiver/ esc/ bec issues? Please help | Cechini | Axial Wraith | 6 | 01-31-2013 02:03 PM |
Wraith electrical issues. | OhioSuperSport | Electronics | 4 | 03-11-2012 07:59 PM |
