07-10-2020, 06:22 PM | #1 |
Newbie Join Date: Jun 2020 Location: Berwick
| Is there a metallic bronze paint that will work on lexan?
The only one I am finding is testor lacquer spray and I read they won't work on lexan. Is there a metallic bronze available I could use? Sent from my LM-G850 using Tapatalk Last edited by ParkeyOh; 07-10-2020 at 07:12 PM. |
07-10-2020, 08:56 PM | #2 |
Quarry Creeper Join Date: Dec 2013 Location: The Garden State, North of I-80
| Re: Is there a metallic bronze paint that will work on lexan? |
07-10-2020, 08:59 PM | #3 | |
| Re: Is there a metallic bronze paint that will work on lexan? Quote: Sent from my LM-G850 using Tapatalk | |
07-11-2020, 07:50 AM | #4 |
If you do decide to do it, post your final results. |
07-11-2020, 07:51 AM | #5 |
07-11-2020, 02:36 PM | #6 |
Rock Crawler Join Date: Apr 2020 Location: Drums
| Re: Is there a metallic bronze paint that will work on lexan? What local shop? The one on Rt11 on the way to Bloom?
07-11-2020, 02:51 PM | #7 |
Not sure how close Testors champagne gold metallic (2922) is to the bronze you're looking for but I have a brand new can you're welcome to use if you can't find what you want.
07-11-2020, 03:48 PM | #8 |
| Re: Is there a metallic bronze paint that will work on lexan? Yeah. One on way to bloom. There's also a small shop in bloom that I may check. I found the cans I want online. Just shipping 2 cans is absurd lol. The color I'm after is similar to an older Subaru color. Called Java Black Pearl. It's like a metallic black with almost a bronze pearl metallic to it. looks amazing when the sun hits it. So trying to recreate that color. Sent from my LM-G850 using Tapatalk |
07-13-2020, 07:32 PM | #9 |
Rock Stacker Join Date: Jul 2020 Location: Dead Center WA
The Testors lacquer does work on lexan. I use it on slotcar bodies. Apply in multiple very light coats or it will melt the body
07-19-2020, 08:46 AM | #10 | |
Rock Stacker Join Date: Jul 2020 Location: Silver Spring
| Re: Is there a metallic bronze paint that will work on lexan? Quote: | |
07-19-2020, 08:48 AM | #11 | |
Also has anybody ever used clear plastidip on the outside of the body? It seems it would be more scratch resistant that normal lexan. Sent from my LM-G850 using Tapatalk | |
07-22-2020, 06:50 PM | #12 | |
Likely to show gouges more than scratches on bare lexan. If the scratches bother you try waxing the body. | |
07-22-2020, 06:54 PM | #13 | |
I learned that the hard way. Painted 3-4 slot car bodies and the white started flaking before I even mounted them. | |
07-22-2020, 11:04 PM | #14 |
Newbie Join Date: Jan 2015 Location: Weston,Florida
I have use Spaz Stix, make sure you prep well. If you dont i have had that paint flake off. If you do prep the body correctly that paint will get you some cool affects. I have in the past use house of kolors in the past they had a shift changer paint for Lexan.
07-22-2020, 11:08 PM | #15 |
Tamiya makes a copper metallic color https://www.amainhobbies.com/tamiya-...m86014/p125370 |
07-23-2020, 09:10 AM | #16 | |
Jeanethics makes a good point on the instructions. I followed ever step carefully and went against my nature to be super patient with each step. The color change effect is pretty good but I have heard a lot of others complain about it. | |
07-23-2020, 02:24 PM | #17 | |
07-23-2020, 06:11 PM | #18 |
07-23-2020, 07:12 PM | #19 |
Here's Tamiya's PS colors: https://www.tamiyausa.com/blog/ps-pa...polycarbonate/ |
07-23-2020, 07:19 PM | #20 |
Proline has Metallic Copper and Metallic Pewter although lots of people seem to be less than impressed with the adhesion of Proline paints. https://www.prolineracing.com/paint/...lic-copper.asp https://www.prolineracing.com/paint/...lic-pewter.asp |
Is there a metallic bronze paint that will work on lexan? - Similar Threads | ||||
Pactra Lime Ice paint Metallic paint | jeepgod | Paint and Body | 7 | 03-24-2018 01:58 PM |
will this paint work on lexan polycarbonate bodies? | ussprinceton2004 | Paint and Body | 2 | 11-12-2015 02:24 AM |
Pactra Lexan Paint - Black - Yellow - Metallic Blue | y2kgtp | Vendors Paint and Body | 0 | 03-18-2010 04:57 PM |
metallic grey paint | punkuup5150 | Paint and Body | 11 | 12-19-2009 02:39 PM |
copper or metallic brown paint | willyrocket | Paint and Body | 7 | 01-11-2007 04:50 PM |
