05-25-2021, 05:43 PM | #1 |
Newbie Join Date: May 2021 Location: Mckees Rocks
| trx-6 newbie question
I am new to RC crawling, bought my first... Traxxas TRX-6. Love it. I would like to make it a little bit faster but without overpowering it for on the trails, would like to do some mud also. I have a Castle Mamba X sensored and (2) Tekin Roc412 sensored motors that a friend traded me for all my old emaxx parts. Would that be a good match? Would I have to change the stock gearing? |
06-24-2021, 06:54 AM | #2 |
Newbie Join Date: Jun 2021 Location: South PA/North MD/East WV
| Re: trx-6 newbie question
i'm 100% not an expert but i do know that the TRX-6 runs the motor backwards so a sensored setup might be difficult, but if you use a regular non sensored setup you can just swap two leads on the motor. since you have that stuff though, i think its worth it for you to take a look at the manual and see if its easy to reverse it. in my opinion the mamba x is a little overkill so focus on the tekins. i'm not sure if you would have to change the stock gearing. those transmissions are pretty robust though
06-24-2021, 07:45 AM | #3 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
Should be good! Keep an eye on motor temperature if you're gonna bash it or run through mud.
06-24-2021, 08:31 AM | #4 | |
Rock Crawler Join Date: Apr 2020 Location: Northern MN
| Re: trx-6 newbie question Quote:
The Mamba X gets my vote 100%. I love mine. In the programming you can switch motor direction to reverse and the throttle curves are excellent. Holmes Hobbies has great Mamba X tuning videos. | |
06-24-2021, 10:10 AM | #5 |
I run the Mamba-X in my TRX6, works great. You should have a great range of speed with excellent control throughout the range of the throttle. You will want to go into the Castle-Link software and reverse the motor direction; this is due to the portals. Also, you will want to put a dab of dielectric grease on the sensor connectors on the motor and ESC, then plug in the cable; this will keep the water out when running through those muddy conditions. |
06-24-2021, 11:47 AM | #6 |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
What kv are those tekin motors? I briefly ran an rx4 and 2300kv roc412hd in my trx6 before I sold it. It was a good setup for that application, but in my opinion didn’t have the greatest low speed control. It was very useable, but I tend to value low speed control over top speed. That was with a 13t pinion, so stock 11t would have improved low end, but reduced my top speed (which would have been fine). Unless the motors you have are super fast (3500kv+) I would definitely throw that setup in there. You can program motor rotation in the Esc, so that’s not a problem. Anywhere from 1800kv-2700kv I would start with stock gearing and then adjust as needed. Sent from my iPhone using Tapatalk |
06-25-2021, 11:40 AM | #7 |
Rock Crawler Join Date: Feb 2020 Location: Fort Leonard Wood
Those are VERY VERY VERY good choices!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! But they are so good I wouldn't want to waste them in mud. Get faster cheap HH Crawl master sport for $20 bucks, keep the stock ESC. Play in the mud until you get tired of cleaning it. You will have a mess and maybe ruin a couple things but at least save the MambaX and Tenkin for cleaner days. Last edited by MOguy; 06-25-2021 at 12:02 PM. |
trx-6 newbie question - Similar Threads | ||||
Trx-4 Sport Weight Question | pfray | Traxxas TRX-4 | 1 | 04-18-2020 09:09 AM |
Newbie? Running TRX lights off 11.1V | Jackson233 | Electronics | 2 | 11-12-2019 08:31 PM |
TRX-4 newbie | TRX4 | Traxxas Crawlers | 9 | 06-04-2019 06:06 PM |
TRX-4 Traxx question | Brianmcbride99 | Traxxas TRX-4 | 8 | 05-22-2019 04:52 PM |
Trx 4 Bronco question | MackPremo | Traxxas TRX-4 | 4 | 03-30-2018 02:25 PM |
