10-21-2021, 09:11 PM | #1 |
Newbie Join Date: Oct 2021 Location: Columbia
| Newb Question?
Hey Guys, I am new to Crawling and I just bought a Axial Honcho used. My question is can Traxxas XL5HV 3S ESC W/ Titan 21T 550 Reverse Rotation Motor TRX-4 iD Plug be used in this vehicle ? Dose axial motors work with Traxxas esc? Thanks and any help will be great. |
10-21-2021, 10:43 PM | #2 | |
Rock Stacker Join Date: Nov 2015 Location: Chilton County
| Re: Newb Question? Quote:
10-22-2021, 04:58 AM | #3 |
| Re: Newb Question?
I didnt know if the motor would mount up to the transmission? Thank you for your reply. 👍 |
10-22-2021, 06:16 AM | #4 |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
| Re: Newb Question?
Mounting to the transmission is the same between 540 and 550 sized motors, 550 motors are just a little longer. Depending on your configuration you may have to trim some plastic parts to clear the end of the motor. Sent from my iPhone using Tapatalk |
10-22-2021, 01:02 PM | #5 |
| Re: Newb Question?
Thanks for the info and help. 👍
10-25-2021, 08:50 AM | #6 |
| Re: Newb Question?
the traxxassssss electronics rearly last long enuff to swap in to any rig if there not already in there i would set them aside as spares or something and get something thats gona last more than a few batterys my opinion aside once you step up to hobby grade rc cars the parts like motors and escs and servos become more universal so traxxass axial enduro redcat or any of the many brands that are out there can all use the same electronics wheels and bodys parts like axles transmissions and gears are more spacific to the brand but that dosent mean that traxxass axles wont fit on a scx10 or vise versa or using a transmission and skid plate from one brand and a frame from another brand and axles from yet another brand thats what makes a hobby grade rc the abulity to make it what ever you want it to be using basicly universal hobby grade parts mixing and matching brands Last edited by ferp420; 10-25-2021 at 08:53 AM. |
10-26-2021, 10:12 PM | #7 |
| Re: Newb Question?
The Traxxas ESC/motor will work but don't waste your time. Instead buy a HW1080 ESC $50 and Holmes Hobbies Crawlmaster Sport 10t motor $20.
10-27-2021, 03:21 AM | #8 |
Newbie Join Date: Oct 2021 Location: GB
| Re: Newb Question?
I would just go and buy a hobbywing they are very good for crawling. Sent from my M2101K7BNY using Tapatalk |
12-03-2021, 10:51 AM | #9 | |
Newbie Join Date: Oct 2021 Location: San Francisco
Sent from my SM-G973U1 using Tapatalk | |
12-21-2021, 02:12 AM | #10 |
I joined the Band! Join Date: Dec 2021 Location: Houston, TX
| Re: Newb Question?
This is quite helpful, thanks guys.
02-05-2022, 12:25 PM | #11 |
| Re: Newb Question?
I am trying to stretch my Honcho to 12.3 what link is the best for this application?
04-10-2022, 04:03 AM | #12 |
| Re: Newb Question?
In earlier posts I talked about upgrades to this Honcho I have been working on. I am at the point where after stretching this chassis to 12.3 the driveshafts got loose and we’re replaced several times. Ordering has been a problem because the shafts don’t seem to fit right, any help in this area would be great. Thanks again guys 👍
04-10-2022, 07:25 AM | #13 | |
most aftermarked driveshafts will fit you should have the wb8 hd wild boar shafts on that rig stock so you would only need a parts kit to make the shafts longer i have one shaft thats almost a foot long running on 4s there great shafts for being plastic a complete shaft cost almost as much as a decent metal shaft though if you dont already have them on the rig the parts kits are cheap if you already have the cv ends Last edited by ferp420; 04-10-2022 at 07:47 AM. | |
04-10-2022, 07:18 PM | #14 |
| Re: Newb Question?
Thank you for the info, I ordered a new set of wild bore shafts and I am hoping they will do the trick. Thanks again 👍
04-12-2022, 04:20 PM | #15 |
| Re: Newb Question?
Dose anyone know if axial transmitters have cruise control? I know Traxxas has it but not sure about other brands. Thanks guys
Newb Question? - Similar Threads | ||||
Newb Question Try #2 | 3ric85 | Electronics | 6 | 05-01-2013 08:45 PM |
not a newb but have a question of newb stature | Brandon88 | Electronics | 11 | 04-14-2010 08:53 PM |
Newb question to beat all newb questions | vinster888 | Newbie General | 3 | 12-29-2009 07:24 PM |
