11-25-2021, 07:02 AM | #1 |
Newbie Join Date: Oct 2021 Location: Columbia
| New rims
Since I am new at this i am having trouble mounting 2.2tires on a bead lock aluminum rims.It’s seems as though the rims don’t have enough space when putting them together. I’m not sure if I need longer screws or maybe a tire bead modification? Any help or advise would be great . Thank you and Happy Thanks giving |
11-25-2021, 07:39 AM | #2 |
Rock Crawler Join Date: Mar 2021 Location: Santa Barbara
| Re: New rims
What wheels and tires are you using? I'm guessing it's proline tires giving you problems?
11-25-2021, 08:02 AM | #3 |
Rock Crawler Join Date: Apr 2020 Location: Drums
| Re: New rims Probably just need two longer screws to start to "get the sandwich squished together". Then you can add in the stock screws and replace the long ones you used to start. This is actually very common for bead locks.
11-25-2021, 08:39 AM | #4 |
| Re: New rims
you just need to try harder the last thing you want is the bead pulling out of the beadlock if you just cant get it they do make a tool to that presses the wheels together so you can start the screws |
11-25-2021, 08:50 AM | #5 |
| Re: New rims
I got one of these. Very helpful. Could I have made one myself? Sure, but for $14 it's well worth the time savings in my opinion. https://www.ebay.com/itm/30401126858...Cclp%3A2047675 |
11-25-2021, 11:13 AM | #6 |
| Re: New rims
Thanks guys, I appreciate the help I will give that tool a try and I didn’t realize this was a common issue. Thanks again. 👍
11-25-2021, 11:59 AM | #7 |
Rock Crawler Join Date: Nov 2019 Location: Erie
| Re: New rims |
11-25-2021, 01:16 PM | #8 |
| Re: New rims
I was also thinking Portal axles any input and or best ones to use would also be great thanks again guys.
11-25-2021, 02:31 PM | #9 | |
| Re: New rims Quote:
It would help if you would provide a little more context about your project. What are you working on, how do you plan to drive it, what sort of terrain will you be driving on, etc. Last edited by Inspector86; 11-25-2021 at 02:40 PM. | |
11-26-2021, 12:13 PM | #10 |
| Re: New rims
I am working on a Honcho and I was thinking that more clearance would be great without installing a lift kit. I am open to any suggestions also I am just trailing this vehicle but some areas I could use a bit more clearance. Thanks👍
12-05-2021, 11:53 AM | #11 |
| Re: New rims I am just wondering what the difference is between portal axles and lift kits?
12-06-2021, 07:22 AM | #12 |
| Re: New rims
so heres my opinion its not cheap though first get some 2.2 tires and aluminum beadlocks wheels thats probably gona run close to $100 right there then get some new axles its a trail truck so your not climbing rock faces and cliffs so i would get potmetal axles there heavy and helps keep your rig right side up cause lifting it any will make it tippy i would go for ar60 style axles there not portal axles but there vary wide making the rig more stable if you do want portals go with capra axles there wider than scx10 axles and you can get them with potmetal housings aswell ether style your gona look at spending around $150 the portal axle has more gearing inside so there slower than a straight axle great for rock crawling not so great for trail riding there are more moving parts to break and there is more waight to them and they do raise the center of gravity slightly the upside to portals is more clearance more gear reduction and less torque twist and you can use the same shocks you have already the portal boxes will provide the needed lift for bigger tires straight axles are simpler faster and have a lower center of gravity but they have less ground clearence and you would need new shocks to lift the truck in my opinion your in a new truck price range a few bucks more and you could be looking at the redcats the traxxasses a clod buster maybe just something to think about Last edited by ferp420; 12-06-2021 at 07:27 AM. |
12-06-2021, 07:58 AM | #13 | |
Pebble Pounder Join Date: Aug 2017 Location: Mesa
| Re: New rims Quote:
Lift kits just raise the vehicle, but the axle clearance remains the same. Lift kits raise the cog dramatically, much worse than portal axles. The popular option now is one of the various aftermarket lcg (low center of gravity) "belly dragger" chassis. They get the truck as low as possible, run the shocks in droop & use either standard or portal axles. | |
12-08-2021, 06:09 PM | #14 |
| Re: New rims
Thank you guys for the response. I totally agree with what both of you guys are saying and I will take this into consideration as I build this Honcho. Thanks again
12-09-2021, 08:09 AM | #15 | |
Rock Crawler Join Date: Feb 2020 Location: Fort Leonard Wood
| Re: New rims Quote:
You will probably pay about $100 for them but you can choose ones you know will fit. The also have there hub hub spacers/weights. Vanquish spacers will also fit but you have to use their screws. | |
New rims - Similar Threads | ||||
rc4wd OEM rims on SCX10? Roxlox on proline rims? Plis help:) | msdelr | Axial SCX-10 | 27 | 05-21-2010 01:50 PM |
