Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: vaterra drive shaft gear
Old 01-23-2022, 09:26 PM   #1
Default vaterra drive shaft gear
I have the vaterra k10 just want to know the transmission drive shaft gear is it the same as the axial scx10 ?
MRSCX10 is offline   Reply With Quote
Old 01-23-2022, 10:09 PM   #2
Default Re: vaterra drive shaft gear
You might need these to mate non-Vaterra driveshafts to Axial type:
https://www.rpphobby.com/product_p/vps08200.htm
durok is offline   Reply With Quote
Old 01-23-2022, 10:15 PM   #3
thanks yeah I seen them but does the axial scx10 drive shaft gear fit the vaterra ?
Old 01-23-2022, 10:30 PM   #4
No.
lonleycreeper is offline   Reply With Quote
vaterra drive shaft gear - Similar Threads
Drive gear shaft has play in it robertjpjr Axial SCX-10 9 12-08-2013 11:23 PM
Super Shafty Top Shaft drive gear ik632 Axial Wraith 14 08-23-2012 08:41 PM
best way to join a rwvo drive shaft to the output shaft on the axle TRAV Kyosho Crawlers 12 01-29-2012 07:37 PM
