07-04-2022, 03:13 AM | #1 |
Newbie Join Date: Dec 2021 Location: GU
| FS-BS6 blinking red
Hello, I have A FS-GT5, my rig was working fine after trailing in dirt and little water puddles all was fine till I changed out my 3s lipo, and that was all, rig is not working when I turn back on. Battery is fully charged, remote is working. Notice my FS-BS6 receiver is constantly blinking red. Note my receiver is in a axial receiver box and not wet inside. Please assist me in this matter. It suc when ur having fun and have to go back home when it breaks down.
07-04-2022, 03:46 AM | #2 |
Rock Stacker Join Date: Apr 2011 Location: UK
| Re: FS-BS6 blinking red
Have you checked all connectors are dry and tight? Sent from my iPhone using Tapatalk |
07-04-2022, 05:03 AM | #3 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
Rebind. I've had FS receivers randomly unbind.
07-04-2022, 03:08 PM | #4 |
Yes, I tried, on the control, it still says BIND after 5 min of not connecting, I tried again, and still the same. Oh, man hope it's not the receiver itself. and thank you for responding.
07-04-2022, 03:13 PM | #5 |
Yes all connectors are dry, I even left it out in the sun to dry that same day. Same night tried again, nothing tried binding reiciever to motor still the same, control still say BIND for over 5 min.
07-04-2022, 08:37 PM | #6 |
Quarry Creeper Join Date: Dec 2016 Location: Cawston, British Columbia, Canada
A blinking receiver means one of 2 things. 1 - slow blinking means the receiver is not bound to the transmitter. 2 - fast blinking is when the transmitter and receiver are in bind mode. So, if the receiver is slow blinking, it should change to fast blinking when you are in bind mode. The procedure for the Flysky FS-GT5 transmitter to bind with the FS-BS6 receiver is as follows - 1 - With the receiver OFF, the bind plug is inserted to the B/VCC port of the receiver. 2 - The transmitter is OFF and the receiver is powered ON. The receiver status indicator should be blinking slowly. 3 - Press and hold the bind button while turning the transmitter ON. 4 - The receiver's status indicator should now be blinking fast. This indicates it is (trying) binding with the transmitter. 5 - Once the transmitter and receiver bind to each other, the transmitter will exit bind mode. 6 - Turn the power to the receiver OFF and remove the bind plug. 7 - May not be necessary to turn the transmitter OFF now, but I like to do it anyway. 8 - Now use the normal power ON sequence - transmitter 1st and receiver 2nd. If binding was successful, the receiver status indicator should be on solid. Another thing to try, remove all the plugs from the receiver except the bind plug and the plug providing power to the receiver (usually the plug from the ESC) When you connect the battery, do you get the initialization beeps? 3 short beeps for your 3S battery and then a long beep indicating the system is ready to go. And, what is the status indicator on the ESC doing? Flashing, on solid, ? It would help to know what ESC you are using as well. Hope this helps and good luck. |
07-05-2022, 12:45 AM | #7 |
Yes, I tried all steps to bind but no luck, on the receiver side 5 blinks then stop for half a sec then continue to blink 5 times again, also I'm running a Spektrum RC Firma 2-in-1 Brushless ESC & Motor Crawler System (2300Kv), button blinks I guess waiting to bind to receiver. Thank you all for assisting me.
FS-BS6 blinking red - Similar Threads | ||||
SCX24 ESC Blinking Red, No Power to Motor | Timotheus | Micro Scale Rigs | 5 | 07-10-2020 07:41 AM |
Hobbywing 1080 blinking red lights | 83trekker83 | Electronics | 2 | 06-30-2019 09:36 PM |
AE -5 Esc blinking red light | Norcalwheeler | Axial Wraith | 8 | 01-13-2015 06:37 AM |
Axial AE-1 ESC problems. red/green blinking, does nothing. | fastline | Electronics | 1 | 11-10-2014 09:39 PM |
Got a blinking red/green LED on my ESC, but no power | Flatty | Electronics | 18 | 06-04-2012 08:28 PM |
