Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: installing electronics
Old 12-27-2007, 07:45 PM   #1
Default installing electronics
all the building is done except the tires.
in the instruction book it shows the esc and rx mounted upside down on the plate under the battery.
i will be mounting a 8 cell split basttery pack on top of the aqxils.
is there a better way / place to mount the rx and esc than up side down on the battery plate?
some pic would work wonders
thx Dirby
Dirby is offline   Reply With Quote
Old 12-28-2007, 01:40 AM   #2
thx Dirby
It would help if we knew what type of chassis/truck you are working on.I assume that it is an Axial.If you are mounting the battery on the axle,mount the electronics on top of the battery plate.Or you could make some mounts to set them lower in the chassis,or possibly on the rear axle.IMO the lower the better.
jcnalley is offline   Reply With Quote
Old 12-28-2007, 02:22 AM   #3
MWRCA'er
Mnster's Avatar
All setups are different, try and see is the best method.
Mnster is offline   Reply With Quote
Old 12-28-2007, 04:44 AM   #4
look in the ax10 section. there are tons of pics of every which way you could set up your truck.
grapegoat is offline   Reply With Quote
Old 12-28-2007, 10:17 AM   #5
i looked in the axial section and started this thread there.
all i got was this thread moved to here and third digree burns on my ass from some of the premadonas that are on the axial thread.
i thought this was going to be fun to get into.
boy was i wrong.
Dirby
Old 12-28-2007, 10:26 AM   #6
enjoy
http://gallery.mac.com/xtremeracingteam
jmizoguchi is offline   Reply With Quote
Old 12-28-2007, 11:00 AM   #7
Damn-I need a chump RT!!!
yotachump's Avatar
i've found this in the AX10 section in about 10sec.
Please search harder
just searched Electronics Layout,Electronics mount
Click
Electronics Layout
Electronics mount
yotachump is offline   Reply With Quote
Old 12-28-2007, 04:43 PM   #8
boy was i wrong.
Dirby
Hey Dirby its kinda like the baja fourm this is rodman i also bought the a 10 its been fun but getting info from these old 2000 post guys ( I would love to see there first post) has been very degrading most of them think there God and even helping someone might tarnish there god loving peers I know that there is a search for topics but being new to rock crawling there is a lot of lingo to try and figure out so searching a topic was hard by not knowing this lingo i also looked for a few days and never really could get a topic for what i was asking once i asked and was shown what i was talking about i learned that i needed this part for this result this is what a fourm is for with out asking i would have never known how to get there SO TO ALL YOU SENIOR MEMBERS GET OVER IT AND JUST GIVE SOME HELP YOU WERE ALL THE SAME AS WE WERE ON YOUR FIRST POSTS THIS IS A FOURM FOR HELP EVEN IF THE HELP IS TO GET US STARTED IN THIS COOL HOBBY!!!!!!!!!!!!!!!!!!!!!!!!!!
crawlman is offline   Reply With Quote
Old 12-28-2007, 05:11 PM   #9
K_B
This was good advice right here. Just experiment. Since you're mounting the battery on the front axle, just put the receiver and speedo on the top plate. If it's performance isn't acceptable to you, then put it under the plate instead and see if that make a difference. It won't be big difference because the receiver and speed control don't weigh much and if you're not competing, it shouldn't really matter. Either way, you learn faster from actually doing rather than sifting through posts on a forum.
You got burned in that other thread because, as I read it, you LOST a shock piston and then started complaining that Axial didn't include enough parts to complete the truck.
K_B is offline   Reply With Quote
Old 12-28-2007, 05:28 PM   #10
A great big thx to
YOTACHUMP
he sent me a link and after looking at it for some time i made the mod.
after moving the top cross pieces down to where they link up with the y i cut the aluninum top plate and mounted theese on the cross plate.
will mount the rx in the rear and the esc in the front.
where do i mount the switch and bec?
thx Dirby
Old 12-28-2007, 05:33 PM   #11
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
There is a hole on the axial top plate to mount the switch through, check out the manual if you cant find it. The BEC can be mounted anywhere you have room, but preferably far away from the RX.
JohnRobHolmes is offline   Reply With Quote
Old 12-28-2007, 06:37 PM   #12
jiohn.
i looked in the axial manual and there is no reference to the switch mounting on the aluminum rop plate
there is somthing about mounting the antenna though.
thx Dirby
Old 12-28-2007, 07:43 PM   #13
yotachump's Avatar
jiohn.
thx Dirby
look at the pick of my truck and youll see the BEC mounted and youll see the Antenna laying down.
i dont use the on and off switch anymore, soldered the wires together.
Old 12-28-2007, 08:30 PM   #14
well i got all the electronics installed where they are going to go.
batterys on a plate over the axils held on with velcro.'
everything is held on with velcro.
rx on a plate just behind main gear.
bec and esc on a plate just in front of motor.
now comes the fun part.
figureing out where all the wires plug into and getting them there.
thx Dirby
Old 12-28-2007, 08:52 PM   #15
OCCUPY RCC!
dezfan's Avatar
Great to see your making progress.
I'll tune in again tomorrow to see how the wiring installation goes!
dezfan is offline   Reply With Quote
Old 12-28-2007, 09:07 PM   #16
yotachump's Avatar
thx Dirby
thats easy CH1 servo, CH2 ESC, BEC plugs into the BC/Batt slot.
Old 12-28-2007, 11:06 PM   #17
i hooked all the wires up with the bec the bec light came on but nothing else happend.
the red light on the rx came on for a split second than it stoped burning.
i dc the bec and hooked it all up again and to my surprize it all worked the tx and rx binded.
it had right and left steeruing and the throttle worked when i gave it throttle.
but than i discovered the pinion that i stripped earlier came loose and the gears wern't moveing.
probably going to have to wait for fhd to get me a new pinion.
oh well it's a start anyway.
wonder why the bec didn't work?
Dirby.
Old 12-28-2007, 11:10 PM   #18
yotachump's Avatar
Dirby.
what BEC and ESC are you using
Old 12-28-2007, 11:19 PM   #19
castle creations.
Dirb
Old 12-28-2007, 11:59 PM   #20
yotachump's Avatar
castle creations.
Dirb
BEC and ESC mamba max?
