Go Back   RCCrawler Forums > Miscellaneous > Non Crawler RC's
Thread: cc's 9000kv brushless motor
Old 11-25-2008, 02:09 PM   #1
Default cc's 9000kv brushless motor
any one have any experience w/ their castle creations 9000kv motor?
i just saw it on their site but cant seen to find it again
NeXt559 is offline   Reply With Quote
Old 11-25-2008, 02:14 PM   #2
MODERATOR™
EeePee's Avatar
Was it maybe Tekin's site?
http://www.teamtekin.com/blmotors.html#redlines
EeePee is offline   Reply With Quote
Old 11-25-2008, 02:21 PM   #3
I thought the general rule of thumb was 50,000 rpm's max (due to the bearings in the motors). so with a 9000 rpm/v motor you should only run 6V max.
gear down, volt up
I'd say go with the VXL motor (3500kv) or the 4600kv and a 4s lipo
this will keep everything pretty cool and last a long time.
engineerjoe is offline   Reply With Quote
Old 11-25-2008, 02:25 PM   #4
Colt Python/SR9c
TwistedCreations's Avatar
http://www.castlecreations.com/products/cms36-9000.html
TwistedCreations is offline   Reply With Quote
Old 11-25-2008, 02:32 PM   #5
Originally Posted by TwistedCreations View Post
wow!! 100k bearings! nevermind what I said before, go with this!!!!
Old 11-25-2008, 02:41 PM   #6
ΜΟΛΩΝ ΛΑΒΕ
chip cross's Avatar
gear down, volt up
Where did you get that info from ???
3,500Kv x 14.8 = 51,800
4,600 Kv x 14.8 = 68,080
Sorry, but that will not stay cool for long.
chip cross is offline   Reply With Quote
Old 11-25-2008, 03:21 PM   #7
I guess your setup is different than mine.
Mine stays cool unless I WOT (wide open throttle) 2 packs in a row with no down time.
(I will note that I am using A123's so it's at 13.2V, and I am using a sidewinder, not a MM)
I use this setup in two different cars:
1. Slash w/ VXL, 4s2p A123
2. Tamiya Durga w/4600kv 4s1p A123
Old 11-25-2008, 03:45 PM   #8
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
The old castle motors were rated for 60k max. The new rotors are rated at 100k rpm.
JohnRobHolmes is offline   Reply With Quote
Old 11-25-2008, 03:49 PM   #9
ΜΟΛΩΝ ΛΑΒΕ
chip cross's Avatar
WOW, thats gonna get hot.
Old 11-25-2008, 04:02 PM   #10
The bearings will heat up fast, and boil off the oil. But, the rotors can take it
Old 11-25-2008, 04:45 PM   #11
yup thats it
thanks for the link
im going to be puting it into a traxxas slash. honestly i dont even think im going to be using it to its full potential very often. at the monment im running a stock slash w/ a seven cell (*sometimes eight) and it seems plenty fast. w/ a new brushless system especially the 9000kv im probabbly going to keep it at 50% - 75% at most for longevity, but once in a while i want to able to "whip out the bull's balls" when i want to do some speed runs or show off a 12 year old thats running an e revo thinkin he's the s**t
Old 11-25-2008, 05:26 PM   #12
Who's your Daddy-0!
I have the small CC 9000kv for the 1/18 stuff.....FAST!!! I run the 7700 in the on road stuff.....and they are to fast!
TattooKenny is offline   Reply With Quote
Old 11-25-2008, 06:10 PM   #13
yup thats it
thanks for the link
A 9000kv motor is a very poor choice for a Slash.
skellyo is offline   Reply With Quote
Old 11-25-2008, 06:36 PM   #14
listen to holmes i think he would no what he is talking about.I got a cc4600 on a mamba in a slash and its really all u need.I mean i dont think ur going to be making high speed runs for your youtube buddys.
redmiller is offline   Reply With Quote
Old 11-25-2008, 09:23 PM   #15
im using a 8000kv in my 1/16 scale edm w/ 11 cells . i cant even turn at speed, and this past weekend i ended up shattering a rim and shreading a tire when i hit a piece of glass on the road im planning on converting it to a drag racer actually
.... please elaborate
Originally Posted by redmiller View Post
listen to holmes i think he would no what he is talking about. I got a cc4600 on a mamba in a slash and its really all u need...
like i said im probabbly not going to use all that power, and just run it at full capacity once in a while.
and who said need? i want excess!:grin:
...I mean i dont think ur going to be making high speed runs for your youtube buddys.
i dont see why not?
Old 11-26-2008, 01:07 PM   #16
You have a higher current draw with a higher kv, which means more heat. With the torque required to push a Slash, that motor will be working very hard unless you can gear it down enough to compensate. It's much more efficient to go with a lower kv motor and run on higher voltage to minimize the losses.
How fast do you want to go with it?
Old 11-26-2008, 01:20 PM   #17
A higher KV motor has less resistance, so higher amp draw does not indicate more heat. Efficiency does not corrolate with KV until construction extremes are met. Bearing failure is one extreme.
A higher voltage does allow use of smaller power wires however, since lower battery side amperage is possible for a given power output.
Old 11-26-2008, 02:16 PM   #18
I agree with that. I probably didn't state it as well as I should have.
Do you not agree that the additional torque load placed on a high kv motor in this application will result in an increased current draw and in-turn, more heat?
Old 11-26-2008, 04:24 PM   #19
I do agree there- as you put additional load on a motor it will heat up because of the increased amp draw. A CM36 can only push a vehicle so fast before overheating, this much will not change. You will just be able to hit XX miles an hour on a lower voltage. Harder on the battery, harder on the wires, but motor efficiency will not change.
Take a pede and gear it for 40mph with a 7.4v 6900 and 11.1v 4600 system. The motor heat should be the same. The 6900 system should be more nimble from the lighter weight. The 4600 system will have 1/3 longer runtime from the additional watt/hours added in the pack.
Old 11-26-2008, 05:31 PM   #20
The problem is that you'll have folks gearing a 9000kv for 50mph on 7.4V in the Pede. That's where the problem lies. Some people simply expect it to just be faster because it's a higher kv.
