Go Back   RCCrawler.com Bulletin Board > Miscellaneous > Non Crawler RC's
Thread: tmaxx tranny running electrically?
Old 12-10-2008, 12:47 PM   #1
Default tmaxx tranny running electrically?
I was wondering if anyone out there has converted a tmaxx to electric while keeping the original tranny. I looked at teh specs, and first gear has a little more gearing than the emaxx tranny, but second has less. I was thinking that I might be able to take out the clutches (except the slipper) on the tranny and then just make a custom motor mount. I was wondering if anyone has tried this, or if it is even possible
newpinesap is offline   Reply With Quote
Old 12-10-2008, 12:51 PM   #2
hitman46mod's Avatar
If you can work out an adapter to mount the electric motor in the truck and mount the pinion to it.
hitman46mod is offline   Reply With Quote
Old 12-10-2008, 01:00 PM   #3
that's what I was thinking of doing, but would I need to do any modifications to the tranny?
Old 12-10-2008, 01:26 PM   #4
There is a write up in the maxx crawler section I believe. Here it is:Search button creation
Gula is offline   Reply With Quote
Old 12-10-2008, 05:34 PM   #5
SAVE BODILESS SPORTSMAN!!
Duuuuuuuude's Avatar
I was going to do the same thing untill I found an old Emaxx trans and motor plate for $10. Much easier and cheap as well.
Duuuuuuuude is offline   Reply With Quote
Old 12-11-2008, 11:08 PM   #6
i have done it with out doing any gearing mods but the motor plate has to be perfect in order for it to work right i would just buy a emaxx tranny and save the hassle
usa1man is offline   Reply With Quote
Old 12-12-2008, 10:41 AM   #7
do you know anywhere to buy a really cheap emaxx tranny now?
