03-20-2011, 10:59 AM | #1 |
Newbie Join Date: Dec 2010 Location: folsom
| nqs jet boat
i am looking to get one of these nqd jet boats is this the right one and what do i need to do to it besides electronics? lol look at the controller, and what brushless system works in here? http://cgi.ebay.com/Remote-Control-N...item20b7ed5360 |
03-21-2011, 08:20 AM | #2 |
Quarry Creeper Join Date: Oct 2005 Location: ELLENSBURG, WA
Go over to RCU, go to electric boats. there's a very large thread on them
03-21-2011, 08:34 AM | #3 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
Yeah that is the one. There was a bunch of us last year messing around with them. There is actually a really good thread, I think in chit chat started by Toyofast last spring that has most of the really good information we could find across the net. Here it is: Jet boats anyone? I also started one in the Colorado section.. Here is the one I started: Jet Boat series/get togethers. Hope this helps. |
03-21-2011, 07:01 PM | #4 |
thanks turtle that helped jus one more thing what do i need to get for it, is the jet drive thats in there good? and what size motor works cuz i was thinking bout putting in a mamba system http://www.b-p-p.com/product.php?pro...&cat=39&page=1 |
03-21-2011, 08:03 PM | #5 |
Newbie Join Date: Jan 2009 Location: Montana
The drive that comes with this boat will work quite well and the motor that you need to run it with should 3000kv or less to run on 3s. 3500kv or higher should only run on 2s battery. Motor size should be a 380 size motor or 28mm can works best. Also the impeller shaft is 2.3mm and the coupler is 2.3mm on both sides. If you use a motor with a larger shaft you'll have to get a different coupler as well.
03-21-2011, 11:10 PM | #6 |
thx damfurst i think i might actually buy one of these considering there only 30 bucks ill prolly get bored quick but im only gunna have bout 70 dollars into it considering i already have most electronics |
03-21-2011, 11:16 PM | #7 |
Or drill it out, I ran the traxxas 1/16th scale system in mine and it worked well, though I considered it a little light to keep the boat primed (unless weight was added). I ran the traxxas 540 system in it and it worked extremely well, granted I was running it on a graupner drive, but they look almost identical. I did end up getting a different coupler, I was blowing the stock ones up every time I took it out so I went to a steel one. Word of advice though from someone who experienced it. Do not run the boat if its not in water. My receiver got wet one day and pinned the throttle full I pulled it out of the water to unplug the battery and in the matter of a minute or so the the drive melted down anything that was plastic from the heat generated from the shaft spinning so fast. Other then that have fun. Im trying to rebuild the three I have right now for some fun spring time run off. |
03-25-2011, 03:55 PM | #8 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
heres my thread if ya hadnt seen it.. Nqd jet boat traxxas vxl brushless 1/16th is waterproof motor/esc.. its what everyone i know runs in thiers.. |
