Go Back   RCCrawler Forums > Miscellaneous > Non Crawler RC's
Thread: LS V8, Turbo'd, widebody Hilux drift truck. Phew...
Old 11-28-2015, 08:43 PM   #21
Default Re: LS V8, Turbo'd, widebody Hilux drift truck. Phew...
Looks sick man....i say ditch the hood so u can see that nice motor setup and detail the crap out of the engine bay
gsrcivic is offline   Reply With Quote
Old 11-28-2015, 09:45 PM   #22
Originally Posted by Atchley View Post
Gonna look sick dude! I've been trying to get into drifting. I picked up a MSD ms01d a few months ago and I'm getting better at holding my slides.
Is that a rwd drift car? I just bought an eagle racing tt02 that should be here in the next few weeks which is rwd. Pretty psyched.
Sent from my N9518 using Tapatalk
BigChevyTruckin is offline   Reply With Quote
Old 11-28-2015, 09:46 PM   #23
Oh don't you worry I'll be running it with no hood quite often. That's the joy of the quick remove hood.
Old 11-28-2015, 10:19 PM   #24
Nope, awd counter steer. I want to try rwd drifting. I may pick up another car for that.
Atchley is offline   Reply With Quote
Old 11-28-2015, 10:25 PM   #25
I heard that its best to go from awd to rwd right away. It's mostly the same concept. Huck it out there and be ready to work it. I think rwd drifting is going to be a ton of fun. I can't wait until it comes in the mail. Going to be running a castle 4600kv setup which is almost equivalent to an 8.5t. Should be good enough.
Old 11-29-2015, 07:47 PM   #26
Well, got some stuff done today. Not too much at all though. The hood took a TON of time.
Well first, I didn't like the ride height of the truck. Mainly, the fact that I could see the chassis from under the rocker panels. So I decided to raise the wheel openings about 3/8 of an inch.
Before.
After.
And theeeeeen that raised another problem. Now the motor and turbo stuck another 3/8 of an inch out of the hood. So I was faced with another problem. Either run no hood, which is cool, or chop the hood up majorly to clearance it. The way I look at it, If there's an opportunity to cut stuff, do it. So I did.
Honest opinions on the hood please. Not sure how I feel on the hood... Mainly because cowl induction hoods are a Chevy thing... Ewwwww..
Old 11-29-2015, 08:11 PM   #27
I'm digging on it. It is an LS swap and all...
Brake Weight is offline   Reply With Quote
Old 11-30-2015, 08:07 AM   #28
Ugh Monday's.
Old 11-30-2015, 08:13 AM   #29
Im digging the hood with the cowl induction and im especially digging how u have the hole for the turbo cut out so u can see a majority of the turbo itself.....naw u just need a strut bar and exhaust lol....bumper exiting if i may start the dilemma....keep up the work man i always like seeing different builds u make they work look easy i may have to try a hand at that stuff....digging the drop as well makes it look mean
Old 11-30-2015, 08:46 AM   #30
Don't you worry. Exhaust is planned. Not sure if I can do much of a strut bar motor is about .010" from the hood as it is haha... Also going to plumb the turbo in with an intercooler as well.
Old 11-30-2015, 09:12 AM   #31
Man I'd this turning out cool!!!! Love the turbo LS
gearhead79 is offline   Reply With Quote
Old 11-30-2015, 09:31 AM   #32
Thanks man!
Old 11-30-2015, 10:52 AM   #33
Diggin the hood work, turbo peeking out is awesome, cowl is well done as well.
joe122 is offline   Reply With Quote
Old 11-30-2015, 12:15 PM   #34
Thanks for the kind words!
Old 12-01-2015, 08:43 PM   #35
Well got some work done tonight. Progress!
First off. Made a firewall. Quick and easy. It's a ls swapped toyota truck. So it has a shaved and wire tucked firewall. Hah!
Then I decided to brace the back of it, because the body mounts might be integrated into it, although I'm not sure.
And thennnnn... I found out my header that I flipped was not strong enough. It snapped off. Oh well. So I made some studs.
Drilled out the heads.
Then the header.
Then made some little studs.
Then put them in the header.
Then slid the studs into the head. That's it.
Started working on the exhaust idea I had too but you guys can't see that until it's done!
Old 12-02-2015, 05:55 PM   #36
Not a whole lot done tonight other than shortening the bed to fit the wheelbase. Very self explanatory so here's the pictures.
And a few booty pics.
Old 12-02-2015, 10:15 PM   #37
Where did u git the scale motor, and do they have it in a 4.3L Vortec?
Sent from my XT1058 using Tapatalk
W1ck3d0n3 is offline   Reply With Quote
Old 12-03-2015, 05:57 AM   #38
I got it in a corvette engine pack. Came with a Fuelie 327, a 427 tri-power, and the LS1 I used. Haven't seen a vortec.
Old 01-15-2016, 06:14 PM   #39
Update?
Old 04-03-2016, 05:28 PM   #40
Hey guys. Been a while. Been working on my real drift truck lol... But it's gotten cold all of a sudden so I pulled out the truck today. Got some primer on the fenders, then sanded, more updates soon. Sorry about that guys!
LS V8, Turbo'd, widebody Hilux drift truck. Phew... - Similar Threads
1.9 drift truck neon9 Non Crawler RC's 3 10-05-2015 08:56 PM
my new drift truck briansbodies Non Crawler RC's 20 06-13-2010 04:01 PM
Anyone else in colorado own a Turbo'd Dodge? TwistedXT Chit Chat 10 11-09-2006 07:35 PM
