03-26-2017, 12:23 PM | #1 |
RCC Addict Join Date: May 2009 Location: Weston
| Rjohns Rock Rey
I decided to start my own here instead of jumping in one the generic one. Started with tear down and added some Losi aluminum, CCBEc and a Protek 170TBL servo. Then I went for some Powrrstroke shocks and changed the diff fluid out for 1mil front and center. I picked up a MC 3rd member but it's not made for the RR and needed a little help to clear the larger gear. Then it was off the JEC for some links. I love these things and use them on almost all of my stuff so why stop now? Got it all back together and took it out for a quick run when this happened to the center diff. I guess it's common on Losi's and people replace these with xray washers. The front output tried to make a getaway and push through the washer. Xray washers are ordered so I'll be dropping them in the front and center diff this week. I haven't decided on wheels and tires yet but the foam in the stocks is way too soft and has to go soon. |
03-26-2017, 12:37 PM | #2 |
| Re: Rjohns Rock Rey
I have a couple quick videos Not sure a Yeti can do this? Got Steering? https://youtu.be/Ts0fCekH7Z8 Straight off the stairs? No problem. https://youtu.be/iMHU2DrEqdA https://youtu.be/5uSWQ5jJlvA |
03-26-2017, 01:14 PM | #3 |
Pebble Pounder Join Date: Aug 2015 Location: Red Hill, PA
| Re: Rjohns Rock Rey
That's awsome! Can't wait to see what you do with yours. Got a few things on order right now for mine! I have to agree that the steering is so nice with this truck. |
03-26-2017, 09:11 PM | #4 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: Rjohns Rock Rey
Whats the part number for the xray washers?
03-26-2017, 09:59 PM | #5 |
| Re: Rjohns Rock Rey
964050. I didn't check the size of the original though. Hopefully they fit, if not I'll make them fit.
03-28-2017, 02:37 PM | #6 |
| Re: Rjohns Rock Rey
Let us know if they fit or what you did to get them to fit. I already ordered the Xray washers.
03-29-2017, 01:50 PM | #7 |
| Rjohns Rock Rey
Got the washers in. Fit like a glove and felt much stronger then the Losi washers. |
03-29-2017, 01:59 PM | #8 |
| Re: Rjohns Rock Rey
Sweet, my washers showed up today. Thanks for the update. What size is the pin? Wonder if a longer one would add more insurance. And what weight you going to run now? |
03-29-2017, 02:08 PM | #9 |
| Re: Rjohns Rock Rey
A longer pin would help but it won't fit in the gear. I filled it with Badhorsie locking grease this time around. |
03-29-2017, 03:16 PM | #10 |
| Re: Rjohns Rock Rey
Front and center diff? Let us know how it is, Im thinking about using that or 20m.
04-09-2017, 06:20 PM | #11 |
| Re: Rjohns Rock Rey
Pulled my center diff today, the stock washer is 0.4mm thick and the xray is 0.3mm. Wonder if its anything to worry about? I figured it was going to be the other way around on thickness.
04-09-2017, 06:48 PM | #12 |
| Re: Rjohns Rock Rey
Badhorsie in the center right now. I put 2 batteries through it and haven't had an issue with the center diff. I didn't even check the thickness. I don't worry about that stuff so much, I just put it together by feel and if it works it works. Lol
04-09-2017, 08:18 PM | #13 |
| Re: Rjohns Rock Rey
For sure. How do you like the bad horsies? Good lock up with some give? I picked up some macks silicone putty ear plugs to try.
04-11-2017, 01:17 PM | #14 |
Newbie Join Date: Mar 2017 Location: ELKHORN
| Re: Rjohns Rock Rey |
04-11-2017, 02:34 PM | #15 |
| Re: Rjohns Rock Rey
You can fit 2 each side making it 0.6mm thick. Or I found some 5x14x0.5 steel washers to try.
04-11-2017, 02:38 PM | #16 |
| Re: Rjohns Rock Rey
Did you have a problem using 1? Mine seems to be fine.
04-11-2017, 04:59 PM | #17 |
| Re: Rjohns Rock Rey
Lol no, but figured it wouldn't hurt. I don't want to risk the same thing happening to these Xray washers like stock. But maybe the Xray washers are better material? So how's the bad horsies? |
04-11-2017, 05:31 PM | #18 |
| Re: Rjohns Rock Rey
I think it's the material. A lot of the SCTE racers have the same issue with the Losi washers. I read on their forum that some switch to the Xray washers. The badhorsies is ok. It's not much of a diff locker so it's good as long as you don't plan on any slow crawling. I want to compare it to the 20mil but I can't for the life of me remember where I put it. Lol. As soon as I find it I will. I think I like the racers edge diff locking putty better. It's pretty much just silly putty but it gets it much closer to being locked. |
04-11-2017, 07:22 PM | #19 |
| Re: Rjohns Rock Rey
Thanks for the update. Thats why Ive been waiting to buy 20m or bad horsies because I figured it was like that. I'll give this macks a try but if not I'll have to give that racer edges a try. Seems like thats what Im looking for.
Rjohns Rock Rey - Similar Threads | ||||
Cat's Rock Rey | Arctic Cat ZRT | Losi Rock Rey | 53 | 11-01-2020 07:32 AM |
Yeti vs Rock Rey | Rybroca | Non Crawler RC's | 121 | 04-19-2017 05:18 PM |
Yeti or Rock Rey | hozzerr1 | Axial Yeti | 43 | 04-15-2017 07:32 PM |
Losi Baja Rey and Rock Rey Aluminum Hop-ups - In Stock! | RPP Hobby | RPP Hobby | 4 | 03-22-2017 04:30 PM |
Losi Rock Rey 4WD Rock Racer Open for Pre-Order | RPP Hobby | RPP Hobby | 1 | 01-04-2017 06:18 PM |
