07-08-2017, 10:12 AM | #1 |
Quarry Creeper Join Date: Aug 2014 Location: home
| Pinion size
Is .5 mod = 48p? Sent from my LGAS375 using Tapatalk |
07-08-2017, 10:16 AM | #2 |
| Re: Pinion size
No, but it is so close that you can get away with running one with the other in a pinch.
07-08-2017, 10:32 AM | #3 |
| Re: Pinion size
I'm trying to find .5p gear with 1/8 bore Sent from my LGAS375 using Tapatalk |
07-08-2017, 10:48 AM | #4 |
| Re: Pinion size
I didn't have any luck with the same, so I ended up just drilling out a 2mm bore .5 mod pinion. What car is it going on? You might have better luck finding a 48p spur and switching both, would likely be easier in the long run.
07-08-2017, 12:59 PM | #5 |
| Re: Pinion size
Latrax Rally... I've found mini motors with 2mm & 1/8in shafts..most of the ones i like have 1/8in Sent from my LGAS375 using Tapatalk |
Pinion size - Similar Threads | ||||
Pinion size help | SkyJacked | Axial SCX-10 | 0 | 02-23-2014 03:40 PM |
Pinion size? | twisted up | Newbie General | 3 | 06-09-2011 07:46 PM |
what size pinion? | ninetwofiveRC | Venom Creeper | 3 | 12-16-2010 07:09 PM |
Pinion size | drzjohn | Team Losi Comp Crawler | 3 | 09-19-2009 02:16 AM |
what size pinion? | Lange20 | Team Losi Comp Crawler | 2 | 08-16-2009 02:52 AM |
