04-15-2008, 08:52 AM | #1 |
Quarry Creeper Join Date: Sep 2007 Location: detroit
| Need a good way to remove decals from New Bright body!
I have a Dodge ram 1/6 scale New Bright body and would like to remove the cheap stickers on it without damaging the body. I have the thing in the bathtub under some hot soapy water and they are softening but progress is not very promising. I don't want to use anything that will leave any damageing effects so anybody got any suggestions?
04-15-2008, 08:58 AM | #2 |
I wanna be Dave Join Date: May 2006 Location: akron
goof off takes them right off any orange citrus cleaner that is strong will do it and not hurt the plastic.
04-15-2008, 11:07 AM | #3 |
Newbie Join Date: Aug 2007 Location: Kelowna
Hot water works well for removing the decal ,they`re paper, then use WD-40 on the adhesive.
04-15-2008, 11:28 AM | #4 |
Pebble Pounder Join Date: May 2006 Location: Firestone
WD-40 rocks.
04-15-2008, 05:20 PM | #5 |
I wanna be Dave Join Date: Dec 2007 Location: Florida
Goo Gone works fantastic as well... and it smells good too...:-P
04-15-2008, 07:15 PM | #6 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
I used a heat gun on mine ... you can use a blow dryer as well. once you get the paper off you can use acetone (fingernail polish remover), brake parts cleaner or goo gone to get the remaining goo off. Last edited by Locked Up; 04-16-2008 at 08:50 AM. |
04-15-2008, 07:57 PM | #7 |
Pebble Pounder Join Date: Dec 2006 Location: nampa
Goo Gone |
04-15-2008, 08:25 PM | #8 |
I joined the Band! Join Date: Oct 2006 Location: RcFanatics.net
Put a blow drier on there, then peel them off with a tweezers. If theres any adhesive left use goo gone to get rid of it.
04-16-2008, 10:19 AM | #9 |
I'm kinda afraid of the Goo Gone of Goof Off stuff. I have seen it it leave terible marks on plastic dashboards over the years. The WD40 sounds a little better but the same goes for the acetone, I think it will leave me with to much "burn" after rubbing the stickers off. I don't own a heat gun but always thought I should so maybe the warden will let me buy one and try a little heat, the hair dryer was only working as good as the bathtub.
04-16-2008, 10:41 AM | #10 |
peel the face of the sticker off then use some window W/ammonia in it. everytime i had to pull tints off my car windows i had to use windex with ammonia to get the glue residue off. hair drier will help soften the glue up though. gonna take some finness but work with it. you can also clean the body with some Bolink Body Wash ( if its still around and you can find it ) and that will help take any last bit of residue off. |
04-16-2008, 11:01 AM | #11 |
Rock Crawler Join Date: Jan 2008 Location: Jonesboro, Arkansas
Rubbing Alcohol |
04-16-2008, 11:16 AM | #12 |
Newbie Join Date: Feb 2007 Location: Ladysmith
I would say that using any chemical like acetone, laquer thinner, or goo be gone you run the risk of damaging the plastic and/or any paint underneath. I have found that the low-tech method of removing the sticker with the use of your fingernail followed up by the sticky tape adhesive removal is the best. What is the "sticky tape adhesive removal" you ask? Again, super low-tech. Just peel off some sticky duct or packing tape then repeatedly stick this to the offending adhesive. It might take a number of applications, but you end up with a perfect surface while not affecting the paint nor the plastic. Sometimes a bit of patience is required, but it saves time in the long run, and perhaps quite a lot of frustration(been there!). As an aside, I have found the New Bright stickers to come off quite well without the use of water. Water just serves to soften the paper integrity/strength and not allow a potential initial clean-as-can-be removal. Being patient and careful are the real keys to success. Cheers. |
04-16-2008, 04:53 PM | #13 |
Quarry Creeper Join Date: Aug 2007 Location: Amarillo, TX
As previously posted heat will be your best friend... Use a hot gun or your typical blow dryer in one corner. Peel it up and shot hot hair, peel, hot air and peel. Simple...
04-16-2008, 05:16 PM | #14 |
I would especially stay away from the Acetone. Your guaranteed it will destroy the Paint and Plastic...just bad advice. As T2NUT said, stay away from any harsh chemical that is a paint remover. Even Goo-gone can be harsh on plastics, thats why I use WD-40, I`ve never had a problem with it. Sometimes low-tech is best. |
04-17-2008, 07:51 AM | #15 |
Rock Crawler Join Date: Apr 2007 Location: St. John's
Ditto on using the WD-40 to remove the glue BUT Make sure that you clean the body REALLY good before you paint. I learned this the hard way when the paint would not dry because of the WD-40 residue left on the shell!!! |
04-17-2008, 08:19 AM | #16 |
I know all about silicone and paint, thanks though. Well as an update I left this thig in the bath tub for 4 hours and thought I had made some progress that I could get back to at a later date. Boy! Was I wrong. Only the stickers that I had removed before setting it aside were the ones to be removed. The water/soap Idea was almost useless. I want something to take the sticker off! I know that the glue residue will take aditional effort but at least I can takee the first step. The residue wont be as hard as the stikers themselves, it will be exposed to my labor at that time.
04-17-2008, 02:19 PM | #17 |
04-17-2008, 08:42 PM | #18 |
| yep which is why I suggested it to. I have used it allot on hard plastic bodys and never ever had any problems.. I have used the wd40 method as well and it works to for the glue residue. but doesnt really make the stickers lift off. some of the toy bodies have super duper stickers that dont want to come off. you may just have to do it the hard way with a finger nail and some time. then use your cleaner of choice for what is left.
04-17-2008, 10:36 PM | #19 |
04-19-2008, 07:01 AM | #20 |
Quarry Creeper Join Date: Dec 2007 Location: Monterey, CA
Goof off is indeed evil. Anyone got an extra sock and plastic baggy? Ronosol or Zippo lighter fluid work fantastic. I've been using that for years to remove adhesive from Laptops and computers in general. Very safe stuff for plastic. eats adhesive for lunch...
