Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: What styrene thickness to use?
Old 09-16-2011, 06:33 PM   #1
Default What styrene thickness to use?
I have been doing some searches on here but have not found what I am looking for. I am starting a crew cab f350 build and it's my first attempt what thickness of styrene should I use for the roof skin and drop bed ect. Thank you for all of your help,
I am here: http://maps.google.com/maps?ll=41.204040,-112.077972
1.9 Jeep TJ Scaler
Axail SCX10 Ford F-250 Tube Rear Scaler
Sent from my iPad
scrapen is offline   Reply With Quote
Old 09-16-2011, 06:50 PM   #2
I'm fairly new to the styrene myself, but what I have been told is that the more curves and contours you have the less thickness you need, and the more weight/abuse you are putting on it the more you need.
.04 or .06 are typical. I use everything from .02 to .06 depending on the situation.
This shell has .06 for the outer fenders and floor, .04 for the inner fenders, and assorted thinner pieces here and there for trim.
Mud Puppy is offline   Reply With Quote
Old 09-17-2011, 07:39 AM   #3
Is there certain type of glue that's recommended?
-NB- is offline   Reply With Quote
Old 09-17-2011, 08:07 AM   #4
Thank you for the help!
1.9 Jeep TJ Scaler
Sent from my iPad
Old 09-17-2011, 11:00 PM   #5
there are various brands, but no matter what you want a "solvent" based glue that actually melts the styrene slightly so the pieces bond into one solid piece.
Old 09-18-2011, 04:17 PM   #6
tenax seems to be the most popular. However, any good plastic welder will work. Just don't use CA unless you want your parts to come apart.
TexasSP is offline   Reply With Quote
Old 09-18-2011, 08:01 PM   #7
Lol I made the ca mistake b4 lasted about 3 seconds
1.9 Jeep TJ Scaler
Sent from my iPad
