02-12-2012, 11:53 AM | #1 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
| Styrene to ABS?
So my LHS doesn't have the Plastruct for dissimilar plastics. I am attempting to make a cab back for a Tamiya body which I believe are ABS. As a test I used some Testors model glue. Is there a good alternative for gluing these together? |
02-12-2012, 12:06 PM | #2 |
RCC Addict Join Date: Apr 2010 Location: Outdoors
| Re: Styrene to ABS?
I found this stuff at Ace Hardware and have pretty good luck with it...it's my go to glue for fixing Barbies! |
02-12-2012, 12:52 PM | #3 |
Rock Stacker Join Date: Nov 2011 Location: clarskville/ but now back in Ohio
| Re: Styrene to ABS?
walmart sells this stuff called E-6000 its in the craft section works great its about 5 or 6 bucks
02-12-2012, 02:56 PM | #4 |
| Re: Styrene to ABS?
It appears the Testors has decent bond. At least I couldn't pop it off with my fingernail with a little pry.
02-12-2012, 04:18 PM | #5 |
| Re: Styrene to ABS? |
02-12-2012, 08:26 PM | #6 |
02-12-2012, 09:01 PM | #7 |
02-13-2012, 09:42 AM | #8 |
| Re: Styrene to ABS?
In the plumbing section of home improvement stores, they sell big cans of glue for plastic pipes. There is a can of glue that is made for dis-similar plastics that you can use in a pinch, just use it very sparingly, it's stronger than the Plastruct glue.
02-13-2012, 11:14 AM | #9 |
Quarry Creeper Join Date: Dec 2009 Location: Honolulu
| Re: Styrene to ABS?
I use the Plasstruct solvent, it's better than the glue. It actually melts the plastic a little and dries quickly, too.
02-13-2012, 12:03 PM | #10 |
I wanna be Dave Join Date: Dec 2005 Location: Orlando
02-13-2012, 12:16 PM | #11 |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
| Re: Styrene to ABS?
I use Oatey ABS cement on my NB JK body and it works great! Since it is a styrene based, it bonds excellent and is sand-able once fully cured. You can find it at just about any hardware store or plumbing supply house. |
02-13-2012, 12:29 PM | #12 |
| Re: Styrene to ABS?
I might have some of that out in the shed with my landscape repair stuff.
02-13-2012, 12:48 PM | #13 |
| Re: Styrene to ABS?
I use a combination of Plastruct plastiweld and a few layers of styrene for reinforcement when I did my first hardbody joining a cab and a bed. Since I am fairly new to these solvents I wanted to make sure I had a bullet proof bond. Now I've learned... Squadron green putty on small accessories such as filling holes and mounting tailgates. Here's a shot of my Tamiya Tundra ABS with styrene, plastruct between the layers, and also Permatex plastic epoxy (THIS STUFF IS RIDICULOUSLY STRONG). In retrospect the Permatex epoxy is really all I needed. Once dry it can be sanded down and literally feels like concrete. Here she is primered up and sanded....still needs some work but I might keep it that way as a beater rig. Just put on door handles, lenses, grill, and figuring out how to mount a front bumper with the brick chopped off my CC-01. |
02-14-2012, 10:49 AM | #14 |
Jeep whore Join Date: Aug 2008 Location: Florida
| Re: Styrene to ABS?
tenax 7r, plastruct plastic weld, plastruct bondene are good options too. i use the plastruct plasticweld and it works great.
02-16-2012, 12:26 PM | #15 |
Pebble Pounder Join Date: Aug 2011 Location: zephyrhills
| Re: Styrene to ABS?
Just out of curiosity, why would you want to bond the cab and the bed together?
02-16-2012, 12:49 PM | #16 |
Rock Crawler Join Date: Jan 2007 Location: Lehigh Valley
| Re: Styrene to ABS?
You really don't want to use a "glue" you are better off with a "plastic welder". Glues will get brittle and then when the body flexes the glue/epoxy may separate. I have bonded styrene to ABS with no problems. As many stated above, Plastruct, Tenax and others that are similar are best
02-16-2012, 02:04 PM | #17 | |
| Re: Styrene to ABS? Quote:
I'm not sure how well the model glue will hold the panel in, but the panel is bonded good with Plastruct Weldene. That stuff works nice. This is what I'm doing. | |
02-16-2012, 06:15 PM | #18 |
Quarry Creeper Join Date: Dec 2008 Location: Lansdale
| Re: Styrene to ABS?
Tenax 7 works great if you can find it. I have two hobby shops by me that sell it. I have heard some areas can't sell it thought. The plastruct stuff works well also. It is the best I have found. Locktite Super glue gel works good for some stuff but is expensive and you don't get much.
Styrene to ABS? - Similar Threads | ||||
What abs bodies would you like to see? | Ben's Madness | General Scale Talk | 186 | 12-03-2020 09:54 AM |
Plexiglass and ABS | bigdodge88 | Paint and Body | 9 | 06-06-2009 08:44 AM |
ABS vs Styrene | AlmstEvil665 | General Scale Talk | 1 | 04-07-2009 06:12 PM |
1/16" to 1/8" ABS or Styrene sheets? | STANG KILLA SS | Chit Chat | 3 | 05-01-2007 02:51 PM |
