![]() | #1 |
Rock Crawler Join Date: Jun 2010 Location: UTAH COUNTY
ok, so I sanded the hilux body and washed it, laid down a few coats of gloss black.. let that dry for an hr and then laid down the clear coat.. well It was cloudy, so I let that dry for an hr or so and hit it with another heavy base coat. I realized after reading the clear coat can that it said the coudyness should go away within 24hrs.. So my question is did I just eff up my whole paint job? will the clear i just based over harded more and make the new base coat crack? what would you do now?
![]() | #2 |
Nope.. ![]() Join Date: Aug 2005 Location: Whiteland, Indiana
I would personally wait it out and see what happens.
![]() | #3 |
Rock Crawler Join Date: Oct 2004 Location: The thumb
I would think if it didn't lift the clearcoat (wrinkle up) withing 5-10 minutes your good to put some clear back over the basecoat once its dried up really well. I'd let if dry out good though before putting any more paint on it.
![]() | #4 |
Newbie ![]() Join Date: Feb 2012 Location: winchester
if you let the first coats of black flash off good between coats, you should be good to go. I would let it sit just to be safe and make sure its not too humid when you paint, that can also make the clear be cloudy
![]() | #5 |
Quarry Creeper Join Date: Aug 2011 Location: Troy
Id personally strip it and start over. Should always primer a styrene body (with actual model primer, auto primer is WAY too coarse). You should wait a few days after you apply a base coat before you clear coat. This allows the base coat to "gas out" which can cause clear coat clouding up. Thinner coats are always better, same works for clear coating too. |
![]() | #6 |
Rock Stacker Join Date: Sep 2009 Location: Virginia
I'm with AG, I'd dunk it in superclean, scrub it good and start over.. Use a model car primer on it and do several light coats.. When you get to paint do the same, a couple of light coats.. You really don't need any heavy coats with primer paint or clear, just several light coats.. Also If your using spray cans, set them in a bowl of warm water before you use them, they spray a lot better, just dry them off good so you don't drip water on you body.
![]() | #7 | |
| ![]() Quote:
Here is my MICRO jeep cj painted with auto primer, base coat and clearcoat. All Sikkens urethane's. http://img31.imageshack.us/img31/3431/buildoff11003.jpg http://img402.imageshack.us/img402/4...ildoff1011.jpg | |
![]() | #8 |
ok........ so I'm so ****ing pissed off right now its not even funny.... Origionally when I hit the clear with the base again it turned out perfect. I should have just left it at that and not touched the god damn thing. I let it sit for a day and decided to hit it with clear today just to finish off the body.. Well it instantly crinkled up.... eff... so i sanded the parts down that crinkled and tried to spray a base.. same thing.. crinkled... ok... so waited for 8hrs and then sanded down THE WHOLE BODY again.. not down to the original color but down so that it made the paint flat black instead of gloss.. So I rinsed off the body and let it dry for a little and also went over it with a towel to help it dry.. Well I sprayed the base again and it crinkled up the whole pass side of the body.. The opposite side that had the problem before... But this time it was way bad... idk what to do.. I'm so ****ing pissed off its not even funny.. I just wasted a couple hrs sanding the damn thing just to have the paint do the same thing... idk what to do but I am running out of ideas as to why it did it again with the base.. I cant pull the grill or the windshield out of the truck because the cage is in the cab and wount let me get the windshield out. The grill is shoe goo'd in. idk.. I am using the krylon fusion "plastic"paint.
![]() | #9 |
well I just spent the last 2 hrs scrapping off all the old paint.. gonna sand it down tomorrow and buy some different paint and go from there.. any recommendations on the paint I should use?
![]() | #10 |
Custom Carbon Fiber ![]() Join Date: Oct 2007 Location: Connecticut :(
Your in Utah ...... what was the temperature when you painted it. Ive had clear coat do that to me before. Id try wet sanding it down and let it dry really good. Try hitting it with some light coats of clear in a warm area. Let the coats breath inbetween, give them some time to dry. If you strip it then try letting your base colors sit over night to breath. When I modded computer cases I had these problems. I figured it was the base coats trying to breath and the clear farging it up. I started letting my paint sit for a day or two and then wet sand them with 5000 paper. After that I could lay some clear and it didnt fog up on me. Good luck! |
![]() | #11 |
| ![]() Yeah, wetsanding it will do the trick. I just found it easier to use something like Tamiya primer because it lays on so smooth you don't need to sand.
![]() | #12 |
Any ideas on what exact brand and type of paint to use? I'm getting ready to try painting it again and don't want the same problems again.
EFF the Cable Company (HELP) | binaryterror | Chit Chat | 10 | 12-05-2011 02:03 AM |
Eff Three Fiddy | Foxracin | Axial SCX-10 | 52 | 09-20-2009 11:07 PM |
SCX Eff Three Fiddy | Foxracin | Scale Videos! | 4 | 06-30-2009 06:03 AM |
What tha eff is dig? | dirty 5-thirty | Newbie General | 7 | 03-25-2009 09:15 PM |
