03-08-2012, 10:38 PM | #1 |
Pebble Pounder Join Date: Aug 2011 Location: Gresham, OR
| Jeep Cherokee grill
I am starting an SCX10 Cherokee project using proline's XJ body. What I want to do is not use the cheesy grill sticker and buy a real grill or make my own. There is only one little issue... I have never worked with styrene and the grill looks pretty complicated. Can anyone point me in the right direction?
04-17-2012, 08:14 AM | #2 |
Newbie Join Date: Sep 2011 Location: Switzerland
| Re: Jeep Cherokee grill
Don't know if you're still looking for one, but I got mine from ebay. Try searching for 'scale crawler grill xj'.
04-21-2012, 08:29 AM | #3 | |
Rock Stacker Join Date: Apr 2012 Location: parts unknown
| Re: Jeep Cherokee grill Quote:
i have seen them many times on ebay and as of the date of my reply there is one up for sale right now so chances are if you search for them you can find one. | |
04-21-2012, 06:28 PM | #4 |
Rock Crawler Join Date: Apr 2010 Location: America
I wished rpphobby or ckrccrawlers carried these, id like to have one for a Comanche build.
04-23-2012, 07:55 AM | #5 |
Yeah, that's the one I got. And according to the guy on ebay this'll fit a proline comanche body as well.
04-23-2012, 08:32 PM | #6 |
Rock Crawler Join Date: Oct 2009 Location: Upstate NY
You'd be amazed how well the grill on the lexan body can turn out, with a little patience. |
04-24-2012, 09:04 AM | #7 |
| Re: Jeep Cherokee grill |
04-24-2012, 06:25 PM | #8 |
Quarry Creeper Join Date: Apr 2012 Location: So. Cal.
04-24-2012, 08:43 PM | #9 |
Thank you, yes...from styrene. I think they'll take some luggage too, they are beefy and the bowing is partially from being fit in tight to the lexan mount points.
04-25-2012, 12:12 AM | #10 |
04-26-2012, 11:13 AM | #11 |
04-26-2012, 12:18 PM | #12 |
Moderator Join Date: Jan 2004 Location: chicago
04-26-2012, 12:39 PM | #13 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
Nice stuff here, guys . Anyone know if there are light buckets to fit the MJ and where to get them?
04-26-2012, 03:10 PM | #14 |
04-26-2012, 04:19 PM | #15 |
RCC Addict Join Date: Apr 2008 Location: Georgia
I bought the ebay grill as well, it hasn't grown on me yet. |
04-26-2012, 09:03 PM | #16 |
Quarry Creeper Join Date: Feb 2012 Location: Canada
04-27-2012, 04:55 AM | #17 |
Newbie Join Date: Jan 2012 Location: Indonesia
What kind of chome paint do you use?
04-27-2012, 06:29 AM | #18 |
The blue is Tamiya PS-59 Dark Blue Met, the silver on the outside is Pactra Indy Silver(for a base coat on the lexan) and Model Master Custom Laquer system Chrysler Bright Platinum Met, to tone it down a little. The number on the can is 28140, and it is a match for paint code PS4. The chrome is Spazstix Mirror Chrome, and I used Pactra Backing Black, RC304, then a light coat of Outlaw Black. It says to use an Acrylic based backer on the chrome, but I didn't see any bad effects to the chrome paint. I did test it on some leftover lexan before hand, though. This test should always be done, any time you are mixing brands or types of paint. A good rule-of-thumb that I have used over the years with painting models is, start with a good primer, then only paint in this order: 1. Laquers (RC paints, duplicolor, etc) 2. Enamels (Krylon, Rustoleum, Testors, Model Master, etc) 3. Acrylic or water based paints If you change this order, you can have some pretty ugly results, from wrinkling to pealing. I once sprayed an R34 with True Blue enamel after Tamiya primer, taped off the window areas and sprayed a laquer clear coat. It all looked great until I went to peal the tape off, it took my clear coat in chunks with it. Key here is to remember what you are using when painting. When you are finshed, if you plan on a repaint in future, take a sharpie and write on the under side of the body, somewhere hidden if you like, the paint used and order used. It would be sad to find out you sprayed your Jeep Wrangler with Krylon and decide later on that you want to repaint with duplicolor. You have to remove the Krylon completely first, as any traces will leave an ugly trace once the duplicolor is applied. Always test first, and let the layers dry completely. Sorry for being long winded, hope this helps some folks out. |
01-31-2013, 06:35 PM | #19 |
Newbie Join Date: Jan 2013 Location: Halton Hills
Your Jeep looks great. What did you use for the head lights. Lenses, buckets etc... Thx |
04-17-2013, 02:55 AM | #20 | |
Pebble Pounder Join Date: Mar 2012 Location: Greece
Jeep Cherokee grill - Similar Threads | ||||
Jeep Rubicon vs. Jeep Cherokee | DAGUL | Scale Videos! | 1 | 03-22-2012 05:26 AM |
TSS Jeep Grill SALE! | STANG KILLA SS | Scale parts | 1 | 08-28-2011 05:05 PM |
jeep grill | losichris | 2.2 Scale Rigs | 6 | 11-17-2010 05:07 AM |
Jeep Cherokee? | dirtymike | Newbie General | 4 | 09-08-2009 03:37 PM |
