01-19-2013, 03:54 PM | #1 |
Rock Crawler Join Date: Jul 2012 Location: Grand rapids
| To much paint
Got a used tamiya f350 body and damn they put a crap load of paint on it, horrible job they did, parts chipping off body lines all messed up cuz or it, it's taken forever to sand this body down, any easier ways to get most the paint off quicker?
01-19-2013, 04:27 PM | #2 |
Rock Crawler Join Date: Aug 2011 Location: Kingsland, GA.
| Re: To much paint
Brake fluid, i cant remember if its dot3 or dot4
01-19-2013, 05:43 PM | #3 |
| Re: To much paint
The only thing I have right now is rubbing alcohol , dunno if that will does anything
01-19-2013, 05:48 PM | #4 |
Rock Crawler Join Date: Dec 2011 Location: thurmont
| Re: To much paint
dot 3 brake fluid works, but dot 4 works even better. its worth the trip to the store because you wont have to sand it forever
01-19-2013, 06:37 PM | #5 |
Rock Crawler Join Date: Apr 2009 Location: NE Ohio
| Re: To much paint
Don't let it soak to long or it will make the plastic soft and can cause the color to actually bleed into the body. --Dan |
01-19-2013, 06:59 PM | #6 |
| Re: To much paint
Thanks
01-19-2013, 07:12 PM | #7 |
| Re: To much paint
Do I just use a rag to rub it and then wash off then repeat ?
01-19-2013, 10:05 PM | #8 |
Newbie Join Date: Dec 2012 Location: Kitimat BC Canada
| Re: To much paint
I would do that ^^ but dont leave it on long as it will start to eat the plastic. Be sure to give it a quick sanding afterwards, or something to remove the oil based brake fluid
To much paint - Similar Threads | ||||
Lexan Shell Paint Disaster, Paint Removal? | Big Tex | Paint and Body | 15 | 02-08-2012 12:58 AM |
Paint mask or easy way to paint houndstooth...ideas? | nascarkeith | Paint and Body | 3 | 01-10-2012 01:57 PM |
Paint: use bully dog paint adhesive | sdogg | Paint and Body | 0 | 11-06-2011 08:41 PM |
anybody ever paint the inside of a body with reg. paint? | 2500hdon37s | Paint and Body | 9 | 05-25-2010 09:28 PM |
