01-20-2013, 11:09 AM | #1 |
Pebble Pounder Join Date: Nov 2012 Location: illinois, rockford
| paint separating from proline body...
i painted my cherokee body and when it gets hit or maybe flexes a good amount the paint pulls its self away from the body. what can i do to fix it? |
01-20-2013, 11:24 AM | #2 |
Rock Crawler Join Date: Mar 2006 Location: Dogpatch
| Re: paint separating from proline body...
Did you use the correct paint? There is a lexan specific paint that flexes with the body and doesn't crack and peel off.I use testors/pactra and Parma lexan body paints with excellent results.
01-20-2013, 12:16 PM | #3 |
RCC Addict Join Date: Feb 2005 Location: Vancouver Island B.C.
| Re: paint separating from proline body... I had a body do this recently and so did a buddy. This both happened on HPI bodies and we both used lexan paint, and washed/dried the bodies before painting them. Id like to know what i can do to avoid this as well. Ive painted at least 16 lexan bodies in the past and no issues till now
01-20-2013, 03:08 PM | #4 |
Fan of wheelspeed Join Date: Jun 2011 Location: Southern IN
Use a green scouring pad or some steel wool on the inside of the body. Lightly rub down the inside, then wash it and once dry paint. Dont go nuts with the scrubbing, just go over it. You wont be able to see any discoloration thru the lexan.
01-21-2013, 02:50 PM | #5 |
spidernad helped me out. i didnt know about the polycarbonate paint i had used tamiya plastics paint. i guess now i have to wait and just buy a whole new body
01-21-2013, 03:40 PM | #6 |
Rock Crawler Join Date: Aug 2011 Location: Kingsland, GA.
you can use dot4 brakecleaner to remove it.
01-21-2013, 04:57 PM | #7 |
Quarry Creeper Join Date: Sep 2012 Location: 01011
Dot4 will work but a big PITA. IMO spend the $35 on a new body with the proper paint/prep methods. I wash with soap and steelwool, dry, rescuff with red scotchbrite, windex, wipe dry and paint. My steps may be a bit over the top but I have yet to get even 1 crack or flake off on any lexan body I prepped this way. Im just starting to mess with the hardbodies which are a completely different beast with prep and paint. Good luck
01-21-2013, 05:18 PM | #8 |
Paint the outside with polycarbonate paint?
01-22-2013, 09:06 AM | #9 |
Lexan bodies are typically painted on the inside but I have done both ways. 1 great look is a silver on the inside with whatever color you choose for your rig on the outside. When the outside gets scraped up it gives the appearance of the sheetmetal under the paint because of the silver on the inside of the lexan body.
01-22-2013, 10:52 AM | #10 |
I've had certain Pactra paints peel off. For example, there are some of the fancy colors that you back with backing black or backing white. Well, it turns out that those aren't' as flexible or sticky as the regular paint and they peel a little. I had spots where I wanted the black and just used backing black. I don't recommend doing that. If you need black, just spray black over the other color and don't worry about the backing black.
01-22-2013, 11:45 AM | #11 | |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: paint separating from proline body... Quote:
01-22-2013, 12:04 PM | #12 |
I think the backing paint are a little different than the regular stuff though. I think they are intended to stick to paint and not to lexan. Either way, I do what you said 99% of the time. It's that 1% of the time you're distracted for some reason and mess it up |
01-22-2013, 08:48 PM | #13 |
I don't think there is a difference in what they stick to but if you shoot on each of the outlaw black and backing. You will see that the outlaw is more transparent than the backing. |
paint separating from proline body... - Similar Threads | ||||
Auto Body paint or model paint in a can ??? | luv2ridemx | Paint and Body | 7 | 07-10-2011 07:40 PM |
anybody ever paint the inside of a body with reg. paint? | 2500hdon37s | Paint and Body | 9 | 05-25-2010 09:28 PM |
Need Some Help Separating Leaf Spring | rcr3fan29 | General Scale Talk | 3 | 01-12-2007 05:42 PM |
