01-21-2013, 05:59 AM | #1 |
Quarry Creeper Join Date: Sep 2011 Location: hemet
| Forest service green
I could use a little help. I want to paint a lexan body "forest service" green. I am not finding anything very close. Has anyone found a color that would be suitable, or has anyone mixed their own out of stock colors? Any tips or leads is much appreciated. |
01-21-2013, 12:22 PM | #2 |
Rock Crawler Join Date: Nov 2006 Location: Holland
| Re: Forest service green
Tamiya PS-54 cobalt green. (rattle can)
01-21-2013, 02:42 PM | #3 |
Quarry Creeper Join Date: Sep 2012 Location: 01011
I used a Tamiya xf-67 which is a nato green for a military build that I think resembles a forest green. Sprayed it with my airbrush and its an acrilic so cleanup is a breeze
01-21-2013, 10:47 PM | #4 |
Thanks for the info. I spent some time looking at the tamiya color chart. There are lots of colors my LHS doesn't carry" may have to order the right color.
01-22-2013, 09:28 PM | #5 |
Well it definitely isn't PS22. too dark. I guess I will track down the PS 54. It looked too blue in the pictures I saw but maybe not.
01-23-2013, 05:20 PM | #6 |
Rock Crawler Join Date: Feb 2012 Location: NORTH SYRACUSE N.Y.
I googled forest service trucks and one of the trucks that came up was a light green close to PACTRA 50'S AQUA like this, its a little darker in person if you could find this in a bottle you could get a darker green also and mix your own pretty easy . Oh it waas not a lexan paint but scuff your lexan and use a adhesion promoter like Bulldog and you shouldnt have any issues , the Dingo in the pic is painted with it using these products |
01-23-2013, 05:35 PM | #7 |
Newbie Join Date: Jan 2013 Location: Midwest
I think the tamiya TS52 is the closest according to the color chart, but I have a feeling it will turn out much lighter than it shows up on their color chart.
01-25-2013, 03:31 PM | #8 |
RCC Addict Join Date: Jun 2011 Location: Lindsborg
backing color may change how it looks too, like that dingo does not appear to have any backing (look through the wheel well. may darken up with a black backing.
01-26-2013, 05:54 AM | #9 |
Thanks for all the ideas. I agree, backing it could change the tint quite a bit.
02-02-2013, 06:43 AM | #10 |
Well back to the drawing board. PS-54 matches the turquoise color of my 67 bronco, but does not portray forest service green. darn it
02-02-2013, 06:48 AM | #11 |
Quarry Creeper Join Date: Oct 2012 Location: high desert CA.
| Re: Forest service green |
02-02-2013, 08:20 AM | #12 |
try posting a pic of the forest service color your looking for . I have seen about 4 different greens associated with the forest service. You could also try contacting a local Forest service shop and seeing if you could get the paint code , take that to your local auto body supply and have it made , some will even put it in a spray can for you . Last edited by paleblue46; 02-02-2013 at 08:24 AM. |
02-02-2013, 06:34 PM | #13 | |
| Re: Forest service green Quote:
02-03-2013, 11:15 AM | #14 |
It depends on how you prep it . Think about the custom painted bug deflectors , they are lexan just thicker , I have used auto paint on a couple of bodies . wash the body , dry it,scuff the body with a scotch brite pad either red or grey , wash it again , dry it spray it with Bulldog adhesion promoter 2 coats with a 5 to 10 minute dry time between coats then do light coats of color should be ok . Oh always do a test on a scrap piece of lexan !!!!!! there are some cheaper lexans out there that dont like the reducers in auto paint . |
02-07-2013, 05:34 AM | #15 | |
02-07-2013, 10:09 AM | #16 |
the key for a automotive style paint I think would be to sand the surface you are painting. if you are doing a inside paint, it might dull the shine a bit, but not enough to worry about. give it something to stick to rather than just laying it down on a slick surface.
03-01-2013, 09:16 PM | #17 |
Thanks for the info everyone.
03-01-2013, 09:44 PM | #18 |
RCC Addict Join Date: Jun 2008 Location: In the woods
Try emerald green.
Forest service green - Similar Threads | ||||
I'm Disappointed with Punk RC's Service...or Lack of Service | Airmaxx23 | Chit Chat | 18 | 05-11-2013 05:09 PM |
Green Forest Challenge | voytec9000 | Scale Videos! | 12 | 08-25-2010 05:20 PM |
Forest Falls 4-17-10 | ZoSo | Scale Videos! | 10 | 05-24-2010 10:10 PM |
USDA Forest service trail rig | thumper68 | 1.9 Scale Rigs | 4 | 04-06-2010 05:34 AM |
