04-29-2013, 06:25 PM | #1 |
Rock Stacker Join Date: Nov 2010 Location: Montreal qc canada
| Drilling holes after painting? meh
totally forgot to drill holes on my cherokee body proline for my dingo .... is it too late? can you guys give me a good advice to do a body post reaming job? let me know how you do it i know most painters never drill or even trim bodies first so i guess im not ''doomed'' |
04-29-2013, 07:36 PM | #2 |
| Re: Drilling holes after painting? meh
You can use the old trick of putting some paint on the tip of the body post then set the body down on the truck. When you pull it back off you'll have little dabs of paint on the underside of the body showing you where to drill.
04-29-2013, 08:07 PM | #3 | |
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
| Re: Drilling holes after painting? meh Quote:
I have used this trick before with much success | |
04-29-2013, 08:15 PM | #4 |
Thanks guys! im just scared to use this trick cause when you fit a body for the first time you move it around quite a bit
04-30-2013, 07:14 AM | #5 |
Rock Stacker Join Date: Jan 2012 Location: McAdoo
I used dabs of grease and just eyed it up real good.
04-30-2013, 12:44 PM | #6 |
Pebble Pounder Join Date: Apr 2008 Location: Appalachia
I broke down and bought this. http://www.tqrcracing.com/shop/produ....asp?p_id=2066 |
04-30-2013, 01:18 PM | #7 |
Quarry Creeper Join Date: Apr 2013 Location: SE PA
man that thing looks pretty cool. wonder how many layers of paint the led will shine thru.
04-30-2013, 02:12 PM | #8 |
Quite a few. It had a little trouble making it thru 3 layers of pactra Aztec gold and the black backing but that's awful thick chunky paint.
04-30-2013, 03:17 PM | #9 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
i had to drill holes through a body that had like 4-5 good coats of green so i put some masking tape on the inside of the body and used model paint and painted squares on the tape and lined it up and pushed down hard on the posts and worn the paint off the paint. you should have dots on where to drill holes.
04-30-2013, 04:26 PM | #10 |
so maybe i just put some painters tape inside in a ''loop'' and press it against the posts and go from there should work i believe. |
04-30-2013, 08:23 PM | #11 |
Quarry Creeper Join Date: Sep 2010 Location: Gettysburg
paint on the post works great but gotta carefully put the body on the post so it doesnt slide around
05-02-2013, 08:04 PM | #12 |
You can always do that, then measure the spots to make sure they are even. When I mount a body that's still clear, I set it on the posts and get it where I like it, then mark the center of the post on the outside with a sharpie. After that, I put a piece of masking tape down the center and across where my marks are and I measure to make sure they are centered.
05-03-2013, 08:30 AM | #13 |
Rock Stacker Join Date: May 2010 Location: Bluefield,WV
This looks like it might do the trick for what you are needing. Not a bad price either Dynamite EZ Body Post Marker Set The first body I ever painted I forgot to ream out the body posts and was looking around for a solution and found this. Instead of waiting and ordering this I just winged it and it came out ok but I think this would have worked better. I used some of my wife's old lipstick on the tip of the body post and marked the body that way. It sounds crazy but it worked, it took a few tries but it wipes off easy so you can try again if you need too. By the way this is the same trick i use to mark door jambs when drilling out for a dead bolt, works every time. |
05-04-2013, 12:41 AM | #14 |
Rock Crawler Join Date: Oct 2011 Location: Canada
I was going ot suggest putting a super bright light (spotlight) on the body and you will see where the posts are. Especially if you can get the light under the shell. I've done this a few times. Those crazy lights for the post are pretty cool. Just make sure to buy a high quality reamer. Don't drill. Ever. even a cheap arse reamer is 1000 times better than drilling. |
05-04-2013, 01:06 PM | #15 |
Newbie Join Date: Feb 2013 Location: Upper Michigan
You can get the body mount foams and put them on the post and align the body and then pros down to get the sticky tape to stick
Drilling holes after painting? meh - Similar Threads | ||||
drilling air holes | arp1500 | Tires and Wheels | 6 | 04-16-2012 03:46 PM |
drilling square holes | YYCADM | Tools, and Procedures | 13 | 10-05-2011 12:44 AM |
Drilling holes in wheels | legion1capone | Newbie General | 19 | 03-25-2009 02:17 PM |
Drilling Holes in rims? | PapaGeno21 | Newbie General | 16 | 02-06-2008 08:29 AM |
Drilling holes for a trans in a tlt | Just Zach | Newbie General | 7 | 12-24-2006 10:12 PM |
