09-15-2013, 06:23 PM | #1 |
Quarry Creeper Join Date: Aug 2013 Location: Fort Worth
Sharing the method I used to put some door lettering on a beater Tamiya F350 high lift build. Started by stripping the body of multiple layers of old paint. The painting started with a gray primer, flat black driver's door and random light misting of flat black for a more weathered look. The goal is to have a scale junkyard dog. I decided on lettering the doors after painting, so I masked off a section of the door and did a light, uneven coat of almond color paint. I did not want perfectly white and crisp lettering. The next step was applying vinyl lettering with the help of an x-acto knife to help get the lettering relatively straight. I penciled in lines before applying the letters to help keep things straight. Fortunately this is a beater project, the tiny letters would be difficult to get perfect. Any type or color of lettering and picture can be used since they are only being used as a paint mask. Here is one side with lettering applied: Mask and paint the body color. This process would be easier if you are painting the whole body at once. Since I decided on this after already painting, I needed to mask off windows etc. The end result worked well for my "auto salvage" build. As a side note, the extended cab also allowed for the Tamiya 3 speed transmission to be moved back and up for much better clearance for crawling. Traxxas driveshafts completed the transmission lift. Next to a stock Tamiya high lift for comparison: Last edited by THX_138; 10-02-2013 at 09:07 PM. |
Tags |
extended cab, f350, lettering, paint tip, stencil |
Beater Scale Build Door Lettering - Similar Threads | ||||
Jims 64 Chevy Beater Build! | Fungi | Losi Micro-Rock Crawler | 153 | 04-11-2014 11:54 PM |
A lil 1:1 beater build | the_ocho | Nevada | 14 | 06-19-2012 12:59 AM |
2.2 beater build... | ridepate | 2.2 Scale Rigs | 9 | 01-07-2012 08:06 PM |
Goat's Trail Beater build | microgoat | 2.2 Scale Rigs | 63 | 03-02-2008 08:47 AM |
